What is the easy-splitting wood
pelican
45
Hey all, I was wondering what wood this is, it's really easy to split wet 17" rounds with my maul. It also has a very potent "woody" smell when split and sort of smooth bark.
I'm a noob when it comes to wood ID, any help would be very appreciated. Thanks.
Here's a few pics.
What is the easy-splitting wood What is the easy-splitting wood What is the easy-splitting wood
Red Oak would be my guess too.
Reactions: ScotO
Clean rounds of red oak split so nice, especially the smaller ones (under 24"). One hit with the maul and there is a clean "ping" as it flies apart...
KaptJaq
Reactions: ScotO
def red oak
Thanks guys. What are the chances if I split it all to the size in my pics it will be burnable this season if kept in the sun starting today?
I would say slim... Oak splits easy, burns hot and long, but takes forever to dry. Small splits, off the ground, in a single layer in the sun might get close to ready (under 25%) but I doubt it...
KaptJaq
Reactions: ScotO
That stuff could be split into 1" slivers and still not ready by this winter......oak isn't a speedy seasoning wood. It generally needs 2-3 years to be ready to burn. Tuck it aside and save it, you'll be glad you did.
Thanks Scott, I was afraid of that.
I should have mentioned I took the tree down in the spring and cut into 18" rounds and left out for the summer. Not sure if that helps for my chances of burning this season or not...
Nope... rounds don't season well, splits do ;) Oak takes forever... I have 4 cord of it that I split this year so I feel your pain.
Pelican, lots have had this same scenario......
Wood needs to be split and stacked before.we.can really consider it as "seasoning". If I were you, and you need wood for this year, look for some standing dead ash and maple, or find a local wood seller that has legitimately seasoned wood for sale. Try and get a couple years ahead on your wood stack, you'll be glad you did...
If you are questioning the moisture content of your wood use a multimeter or buy a moisture meter... both work great
https://www.hearth.com/talk/threads/using-a-multimeter-to-measure-wood-moisture-level.40033/
;lol ;lol ;lol <>
As others have stated, you have 2 chances of that being ready for burning this winter; slim and none.
Also you might remember pelican that you have a better chance of the wood drying faster if it is stacked in the wind. Sun is good for sure, but wind is even better. Good luck.
Reactions: NortheastAl
Reactions: Backwoods Savage
2 years minimum , even small splits . 3 years ooh ! Primo burning wood will be grayish ;) . You can burn it in a year , but you wont get the big benefits out of the wood.
Red Oak, I can say this cuz I have about 90% in my stacks of 10-12 cords. It really does take 2-3 years to sason,water will run outtta the chimney cleanout if its under 2 years.
You're lucky to have that oak. You'll appreciate it even more if you let it season. Get it split as soon as possible. It splits nice. Straight splits and very sharp edges.:)
Red oak . . . very little chance of that being ready . . . much better to wait a couple years and really enjoy the oak then. I think this year (or maybe it's next year) I'll finally get to try out some oak I scored 2 or 3 years ago.
  • What is the easy-splitting wood
That's what I think the easy splitting wood is in this post, that's what it has to do with it. In the picture it looks more like Chestnut than Red
Too bad, I thought I was going to be set for the season...I checked today to see which tree it was from and it was from a large red oak that came down last September from hurricane Sandy ( I couldn't remember if it came from my neighbors trees that were taken down in the spring). Anyway, just checked and there's still about 15 - 20 feet of it left at about 18" diameter. Going to cut it up, split it and forget about it for a while.
