Thanks ....but it's different then mine,I've got an oldie..1995
Mine does not have the bracket with the two bolts...think it had a spring of some sort to hold the auger motor from turning.
I noticed it also has a flat bolt attached to auger motor bracket that is set to hit the cut out switch if the auger jams.
Anyone else with an older stove?
Just checked my stove it's set on 2 and has been running for about half hour and still burning fine
We're getting closer.....
