Heat pump users?
mithesaint
512
NW Ohio
Anyone using a heat pump along with the stove? I'm due to replace the AC unit, and was considering spending a few extra bucks and getting a heat pump instead.
It would be nice to have during the shoulder season, and I'd prefer to have the stove off when the whole family is home and awake. The noise of the fans is mildly annoying, and we have friends with small kids that have never been around a stove before. My nephew burned his hand last year, and I felt terrible about it. My kids are pretty good, but all it takes is a poorly timed trip and fall incident.
I know they're not terribly efficient below 30 degrees, but supposed to be pretty good above that.
So...anyone using one? Is it worth it?
We replaced our central AC with a heat pump last year. We used it for heat when needed in October and all November and December and then switched over to pellets in January. It works well above 32 degrees or so. It is a different type of heat. My house wasn't as warm as it was when we used oil or the pellet stove. I found I would keep the temp on 72 just to feel comfortable. My bill for December increased approx 150 over my normal electric bill without heat or air. Our house is now completely electric unless we use the pellet stove.
I have two heat pumps. One for upstairs in an older, 12 SEER unit that I hardly ever use now that we have an 'empty nest'. For the main part of the house, I have a 15 SEER d.c. drive heat pump that I use. The first year that I had my pellet stoves, I experimented with using them whenever it got down to around 50 degrees to see how the stoves operated. I used more in pellet cost than I had used in electric in prior years. I have a whole house electrical monitoring system called THE ENERGY DETECTIVE that gives me a pretty accurate reading on real-time electric usage so I could see and compare costs. I burned 3 1/2 tons of pellets that year! This is in Georgia, mind you. It does get cold down here and that year was particularly cold with days in a row below freezing and approaching zero. Since then we have been milder and I just use the stoves if the temp gets to 30 or below. I find that it is about break even at 40 degrees but below that it's a question of if you want to hear the heat pump running continuously pumping out luke warm air or the pellet stove creating uneven temps throughout the house. We opt for uneven temps but warmth!
Now with electrical costs going up, pellet stoves are making more and more sense. What makes even MORE sense are coal stoves since BTU'S are much higher per pound and the appliances have taken giant steps in efficiency and looks. I see that you are in Ohio so you surely know that 90% of your electricity was generated using coal, which is being killed by 'The One We Do Not Name'. Your costs are going to 'necessarily skyrocket'.
For shoulder season, I would recommend the highest SEER heat pump you can afford and perhaps even geothermal if you can find someone who will not **** you on the installation costs. Then I would seriously look at coal stoker stoves from
http://www.leisurelinestoves.com/
http://www.readingstove.com/heating-stoves/coal-stoves/swatara-stove.php
http://www.keystoker.com/products.php#as
Do not believe all the crap about coal that you read. It's no dirtier than pellets if you learn how to use it. The heat is much stronger and uniform. Ashes also can be handled cleanly if you do it properly. If you're a 'save the world' type rather than a 'save your family budget' type, then you've made your choice. :)
I have a heat pump but it died in the nineties from lack of use. Found out that the wood stove heated the house better and one window unit upstairs and one downstairs cooled the place for half the price due to duct loses. But I figure that I will get a new one in a few years since they have gotten more efficient and I am getting less efficient. Ours cranked around the clock to keep this barn at 68 during cold weather. They are lot better these days and work down to lower temps.
Given the price of pellets I can see that a heat pump would be more economical to a point. But like my wife says, "How many pellets or how much wood could we buy for the ten grand the heat pump costs. And we would still have to feed it electricity.". Love that lady. A born wood burner. ;lol
Reactions: The Ds and tjnamtiw
Between the ones in the basement and the ones in the attic our ductwork loses are huge. Even with the ones in the attic wrapped. The ones in the basement could be wrapped but a big job.
We have a geothermal unit a little different still a heat pump. Cheaper to operate then burning pellets. Cost a lot more to install then a stove though :)
Take a look at the mini-splits Fujitsu and Mitsubishi they are rated to -5 F. You'd have to read at what efficiency they operate at those temps cant remember.
Only the Mitsubishi models called "Hyper-Heat" have full rated heat output down to +5F. If your electric rate is less than about 10 cents per KWHr, the largest HyperHeat minisplit, 36000 BTU (about $5700) might make some financial sense, with a break-even point of 5 to 8 years. That assumes that you can install it yourself, otherwise the break-even point gets too long (10 years plus)...then it makes no sense to get a heatpump. The break-even point of course depends on your current fuel cost ($ per BTU) as a comparision.
Umm what's a "heat pump" In simple easy to understand, paint by number language?? :)
An air conditioner that takes the heat out of the house in hot weather and reverses and brings it in the house in cold weather.
This is what I have found as well. If its below 40 my pellet stove is much more efficient than the heat pump. If its above 40 my pellet stove will run you out of the house. When its below freezing the heat pump does not really warm your house. It just keeps you from freezing to death. and then the backup heat kicks in and the elec meter starts spinning really fast. Best to use my pellet stove when under 40.
And you are correct about the coal. Great heat. Ask anyone in WV what they think about " The One We Do Not Name"?????
In 2011 put in central air and a heat pump. I don't regret it and it works great. My house is all electric too. I went away for a week in February and heated the house with the heat pump. I use the heat pump for as long as I can then put on the pellet stove. My heat pump is pretty economical too. Pellets aren't the great buy they used to be and all the dust the stove generates.
Funny you should ask; I just had my heat pump installed this weekend to replace the a/c unit. My insert will be my main source of heat, but even that needs help now and then, so the heat pump will be my backup. After installing the heating elements (for when it goes below freezing), my installer cranked it up to 85 for a test. Now, I know it was warmer this weekend (70 degrees), but boy did the heat in the house come up fast! If it were the oil fired baseboard system, it would have taken over an hour to get up to temp. I don't know what it will cost me this winter, but I am sure it will be less than what I forked over for oil last year. I used wood heat as primary, and with the domestic how water adding on to it, It still cost my over $1500 last season. With oil standing at $4.00 a gallon, I think I made the right decision.
I have two heat pumps, oil baseboard and my pellet boiler now tied into the oil baseboard. Use the heat pumps till temps are about 40 or below. Oil is used only when it is below 40 and I am away for more than a couple of days. Last year was the first full year with the pellet boiler. I burned 6 tons of pellets and about 45 gallons of oil (I was away for a week in February). Prior to the pellet boiler I'd burn approx. 1000 gallons of fuel oil. My heat pumps were replaced a couple of years ago with SEER 14 units. They work pretty good. I have SEER 18 at a place I own at the beach. They work great and cost less to operate. If you are replacing the AC go for the heat pumps and do SEER 18. My heating contractor said they now have units as high as SEER 26 but I would let someone else experiment with that technology.
Granted our winters are different but don't think that is the type of heat you will get when it is under 40. Turning on the heat pump when it is 70 outside will not give you anything close to real winter heat.
What everyone is saying is true. When it hits 40 ish outside the heat pump is much less efficient and then the electric heat strips inside the heat pump kicks in (destroying any savings you would have had). It's not like the heat pump is 100% on every degree until it hits 40. It's a gradual decline so if you get cold easy, then maybe the heat pump will only keep you "warm" until it hits 50 outside.
I've had a few heat pumps from different manufactures and all the same results. They are cheap, cheap, cold, cold when used as AC but as heat, not so much. I live in Tennessee when 32 is "deathly" cold to us and I will never have just a heat pump for warmth. We see temps in the teens a few times a year and the heat pump is utterly worthless with it in the teens and I can hear it begging to be turned off because it struggles to keep the house warm to 66 when it is teens outside.
Also, it is a different feeling of heat. It's not as stout a warmth as pellets/wood, not even close.
Reactions: tjnamtiw
I have a modern heat pump and it runs when the thermostat calls for heat whether the stove is going or not. No problem. It has a 2 stage compressor and variable speed air handler. Most of the time I don't hear it running. American Standard Heritage 16. It works well down to about 25F. We start burning wood when temps dip into the 40's regularly.
FWIW, Mini-splits can be incredibly efficient. Several brands can provide good heat at 0::F. There is more talk about them in the green and DIY room. Two good ones are the Mitsubishi HiHeat and the Fujitsu Halcyon. They are also exceptionally quiet.
Reactions: firebroad
I also have a heat pump and like many of the posters have already stated, it works well down to around 35 degrees or so. It's extremely quiet and you struggle to know when its on or off. That being said, the average 3 ton heat pump (15 seer) and air handling system costs approximately $8 -10k. Furthermore, the average life expectancy out of these units is only about 10 years.
I also just installed a Fujitsu Halcyon rated at 17 SEER. Ever since, the weather has been perfect so I have no usage data. From these posts, it sounds like it was a good idea.
[quote="Cincinnati Kid,] Furthermore, the average life expectancy out of these units is only about 10 years.[/quote]
I checked on this with a couple dealers for our unit. They said the average life here is closer 20 yrs.
The mini-splits and their "inverter" technology are really taking a hold in the market right now. I also have the Fujitsu Halcyon system. I have an 18000 btu and a 9,000 btu being pushed by a single outside compressor/inverter that works extremely well both heating and cooling.
And yet they elect a Dem as governor....???!!! My grandfather was a 9 yr old breakerboy at Monongah in 1907. He was sick that day and his mom kept him home. 3 uncles were lost in the worst disaster in US history.
The mini-splits have really become popular but I believe that there is no 'emergency heat' mode on them for when the temp gets too low. Correct?
I too question the 10 year life span estimate. My unit actually has a 10 year parts AND labor warranty. Would they warrant it for its entire life? I doubt that.
no there is not but they are only 12-18k btu not enough to heat most houses anyways when the temp gets real low
