A partial leak on the one connected to the fire box would cause the upper auger to intermittently stop. The same could happen with a damaged connection on the auger motor.you mean the one by the igniter? It looks good the only that was hard was the one on the combustion motor
Just throwing this out. Your stove ran fine until you replaced the auger motor? Could it be possible that the motor you put in does not have the same rotational speed as the one you took out?I have just done as Cladmaster said and now im waiting. The thing was the stove would light but then the pellets were burning so quick that it wasnt pushing out enough pellets and the fire would burn out sometimes giving me an E-2 reading which isnt right because it lights just fine.
The stove was working fine until the auger motor went bad and so I took it apart to replace the auger motor. While I had it apart I decided to clean the combustion motor and put a new gasket in. I cleaned the room air blower replaced a vacuum hose that was getting brittle. New auger gaskets and auger motor. New door gasket and glass gasket. I also gave it a really good cleaning inside and out.
When I got it put back together it was acting like this. Before the motor went gad it was burning just fine aside from the bad motor. I am stumped as to what has changed or went wrong.
Thanks for your help lets see what happens.
Ok, I know I have read that some people have replaced the motors only to find they feed too fast or slow. As an outsider, I just look at the big picture. It just seems to me that everything is working fine, but you're not getting enough pellets in the pot. You can time your motor by watching it turn and time the revolutions per minute. On mine, I have to hold the manual feed to keep the motor running long enough to time it.The motors same to be the same and I am sure that the hoses have been inspected and looked over well. I did as cladmaster said and did a master reset of the control board but now I think that it might be burning to slow still waiting to see what happens. I set it to d and that has made a difference.
Oh yeah he will. I'll be watching to see what he saysIt's possible that the motor is wrong, but if it was ordered from ESW it should be the correct one, but, it could also be a faulty one, so a call to ESW might be needed.
Mike from ESW will chime in when he see's this thread.
Im using Premium Wood Pellet Fuel from Tractor Supply Company, but its the same pellets that I was using before the breakdown.
I oredered the motor from ESW.
Cladmaster the stove has not improved I thought that it was improving but once it caught fire it just burned through everything way to fast. How do I increase the feed rate? As of right now I am letting go into shutdown mode and then I will try a master reset again and change it to a c setting this time. I could also check the motor RPMs What am I looking for with the motor RPMs How long it takes for it to revolve?
