The house we recently purchased was built in 1993 and has a prefab fireplace in it. It is a heat-n-glo model em42. There was a gas log set installed when we move in which suck. No heat at all. The opening dimensions are 34w and 15.5h. There is a thing metal trim piece that the doors seal against that looks like it could be removed. When measure the height from the top of firebrick to the top of opening with the removed we are more like 18in. Inside is 20d and 30 in wide in the back. The hearth brick stand out about 20 inches in front of fireplace.
See below for pictures. I have 3 potential ideas but not sure which would be the best option at a reasonable expense. I would like feedback about these options and also recommendations for other options if you have any.
1) instal an pellet insert with new chimney liner- not sure the opening of the old unit is large enough for this
2) put a free standing stove on the hearth in front of this one. Run the pipe into it and up the chimney. Then can maybe brick off around it?
3) brick over the existing fireplace. Put a stove on the hearth. Run the pipe off to the side and out beside the windo? Not sure if this possible
