I have the Cleva. It gets the job done, but is a little light on suction. It will pick up the stray pellet or two in the ash pan and gets all of the fly ash in the fire box, but I feel that a more powerful vac would make the job easier. If I had it to do over again, I would have bought something with a little more suction.This is the cheapest way if you have the shop vac. http://t.homedepot.com/p/Cleva-5-8-...idge-Filter-and-Pre-Filter-EAT606S/204630984/
2 cleanings? I used a shop vac with a fine dust filter to vac up a drywall dust until the 3 gal vac was almost full with no issues.I also use a regular home depot shop vacation with the hepa filter. I can get about 2 cleanings per filter before it's too clogged to suck anymore. It's amazing how great they do filter.
I can fill my shop vac up twice before the filter is too clogged to suck anything small up in it, sorry ment two shop vacs full. Not two times of cleaning, that would be a walk in stove lol.2 cleanings? I used a shop vac with a fine dust filter to vac up a drywall dust until the 3 gal vac was almost full with no issues.
I agree that was a big bite lol.again I do a lot of research and for the extra money like the fact that when I'm done for what ever reason(didn't wait long enough ) I can put it away in the basement.with out Having to worry that it can burn through a cheap plastic vac and have smokey or worse basment.when I was a newb I did it right after and the only thing that I f--Ed up was the filter holder on the top melted.the cheetah can stand some hot pellets lolNice looking, but 230 bucks.......
Ok, ive always used a shop vac, one everything was DEAD cold and out. Really think I want a ash vac now to keep from breathing in the crud.
Don't want to spend a ton of $$, but something decent, even if its small. Ive seen small Shop Vac brand, cheetahs, etc...
What does everybody here use ?
All I can say is so far so good, the Hearth Country 400 is working fine for me and it was part of my dealers promo on certain Harman stoves last year. So with that in mind my total purchase savings was $220 when I bought the new stove last year.Actually, the Hearth Country 400 sells for about $120.00
I bought mine from Woodland Direct.
I used a shop vac, with the fine (dry wall dust) bag and cloth filter for 4-5 years. Then I had the bright idea that a Cougar brand ash vacuum was the way to go, ie: metal canister, contains all the air borne fly ash etc. I used it for 2 seasons and switched back to the shop vac. I found that this small vacuum had very little suction, and constantly needed to be cleaned (filter system) during a routine cleaning of the stove. I also found that the hose and other parts were a poor fitting design as things would constantly detach from the canister. For a price currently of $230. on Amazon, it is way over priced and has a very poor performance in my opinion. I purchase a two filter bag for the shop vac and I will get one whole season (195 bags of pellets) out of one bag, leaving the second bag for next year. The shop vac will suck up all the ash (cold of course!) from my bin while inside the stove etc. Before, I would have to carry the full bucket outside and dump it into another bag for the garbage, with the ash flying every where in the process. The bag of the two filter bags cost around $18. Doing the math on this, I can get 24 seasons of vacuuming with the filter bags which would add up to the purchase price of the $230. ash vacuum. The plus to all of what I just described it that the shop vac method is 5 times quicker to use(not to mention, 20 times better suction) than ash vacuum.Ok, ive always used a shop vac, one everything was DEAD cold and out. Really think I want a ash vac now to keep from breathing in the crud.
As an update to my Powersmith vs. Cleva post (just got a Cleva free with second stove, but have been using a Powersmith for 2 years): I always thought the Powersmith was loud (more so after 2 years of abuse), but the Cleva makes me want to put in earplugs...this thing screams terribly! Suction seems slightly less the Powersmith and I think I like the casters better then the lack of them on the Cleva.
Lot's of people have mentioned using a shop vac, and I do think that my 5 gal / 5.5hp contractor shop vac would easily do a better job with more suction then either of the ash vacs. It's also significantly quieter. I just prefer the metal canister and nozzle end so that I can vacuum a bit sooner without worry of melting something or having a fire in the vacuum.
