Well kids, I made it through my first year of heating primarily with wood heat. My wood was 9-10 months dry and I didn't notice a difference in how the wood burned until the last month... then I hit the wet stuff with the wood bubbling for a good while before the CAT lit off.
Anyway, I sat on my arse for the Spring/Summer when I should of been collecting more wood to replenish my stacks and get 2 yrs ahead. Well better late than never.... towards the end of the summer I started to hit it hard on weekends:
When I finish the 3rd row, that will be about 4.5 cords. The seasoned stuff (don't forget the stuff way in the back haha) is about 5+ cords. Last winter was very long so I'm thinking "3 rows per year" will do me fine. I'm really not sure how much I used last year as I was stacking some of my first rows completely criss cross to get as much airflow in there as possible. When I criss-crossed some of my stacks that really cut down on the wood density in my stacks.
I'm also no longer covering my stacks. My neighbor does not and he says he's fine, so that will be a welcome change if it works out. I find the tarps a PIA, they get brittle in the winter, and they look like crap. I'm also much better at stacking these days so hopefully that will keep the side yard from looking like too much of a dump going forward. Each stack is about 5 feet tall when you subtract the height of the bricks and 2 x 4s the wood sits on. I'm not comfortable going any higher.
Anyway, I also used my Sooteater for the first time today. I did not clean my chimney at all during my first burning season. Setup:
It works extremely well.
As for how much creosote was built up for a first year burner with less than optimal wood? You be the judge, I'm ecstatic!
90% of the way up with the Sooteater, there was very, very little coming down the chimney, then the last 10%, WHAMO, one big shot of black creosote dislodged and I was done once I hit the rain cap.
Here is a closeup. I'm soooo pleased with the Blaze King Princess insert, that sucker burns clean!:
