Looks like the top and ash lip on these are not very heavy guage metal. http://kansascity.craigslist.org/hsh/4714831138.html
I'm glad it worked out for you. Still a pretty good deal. Give us some pics or video when you get her up and running.Well here are the before and after shots, not the best photos, but hopefully show what has been done.
View attachment 141589 View attachment 141590
435 ain't all that heavy, barely more than a MIL.The mighty Buck is almost 200 lbs. more. So why the higher price, the thermostat? That said, I would be all over that thing.They are plenty heavy.
I was referring to the top and ash lip being made from metal that was heavy enough.435 ain't all that heavy, barely more than a MIL.The mighty Buck is almost 200 lbs. more. So why the higher price, the thermostat? That said, I would be all over that thing.
You can probably answer this as you had one, I think. Did you ever measure that actual loadable firebox volume of the King?If a stove weighs 1,000 pounds and only gets an 8 hour burn, who cares! It's all about the thermostat!
No, I never saw the need to measure it. Easy 40 hour burns was good enough for me. 24 hour burns in the dead of winter are awesome!You can probably answer this as you had one, I think. Did you ever measure that actual loadable firebox volume of the King?
They claim 4.4 but I measure it right at 3.0, so just a bit larger than the Princess. I'd have to measure it but I think your 15.5" height is where the real difference in volume is. I could get a little wood where you said you could, at the sides where the cat shield isn't in the way. The firebox tapers in at the back, so sometimes I put a couple tapered splits on the sides, in effect squaring the box off. I just wish there were some better way to compare stoves. If you look at the EPA numbers, the Buck blows the King and Princess away in emissions, and low- and high-end output. I don't see how that could possibly be, though. I guess that unless you run both stoves yourself, there's really no other way to know, not even testimonials from others who have run the stove that you would like to compare yours to. BTW, the Buck is almost 300 lbs. heavier than a Princess.It comes out close to the advertised 4.3 cu ft. How does the Buck measure up?
Looks like a smokin' deal to me!Well here are the before and after shots, not the best photos, but hopefully show what has been done.
It is hard to compare stoves, especially when the reported efficiencies and BTU's are so different between two seemingly comparable stoves. Unfortunately, efficiency ratings can't be used wih confidence as a comparison with most stoves. If you look at the EPA hang tags on almost every stove, they will say that the stated effeicency isn't the actual number that was found in testing, instead a more desirable "default" number was allowed. Very few manufacturers use the actual test results on the tag, BK,Woodstock, Lopi cape cod just to name a few that come to mind. BTU's, now that's whole other can of worms. Low heat values, high heat values.... Maybe BKVP will see this and elaborate on the topic.They claim 4.4 but I measure it right at 3.0, so just a bit larger than the Princess. I'd have to measure it but I think your 15.5" height is where the real difference in volume is. I could get a little wood where you said you could, at the sides where the cat shield isn't in the way. The firebox tapers in at the back, so sometimes I put a couple tapered splits on the sides, in effect squaring the box off. I just wish there were some better way to compare stoves. If you look at the EPA numbers, the Buck blows the King and Princess away in emissions, and low- and high-end output. I don't see how that could possibly be, though. I guess that unless you run both stoves yourself, there's really no other way to know, not even testimonials from others who have run the stove that you would like to compare yours to. BTW, the Buck is almost 300 lbs. heavier than a Princess.
I've replace all the gaskets in the Buck with OEM and tweaked how the ash pan gasket seals, so I should be able to get longer burns at lower output. I don't need them right now, though, since I need a higher burn rate to combat adverse heating conditions at my MIL's house (stove at one end of the house in a room with glass on 3.5 sides, no wall insulation, 9.5' ceilings, etc.) It is still very easy to load on a 12-hr. schedule. In fact, I have to make sure I don't put too much wood in, or there won't be enough room to re-load. I'm putting some 3M outside window film on the stove room and blowing additional insulation in the ceiling, so I hope to have the old lady peeling off clothes and begging for mercy this season.
