A wood question
Libbynuke
16
Salem, ct
I am new to burning. This is my first few months. I bought a cord of "seasoned" wood. I tested a few pieces and it was around 15%. I then brought some inside and tested it and the majority is 25% or higher. How long will it take to get it the moisture content lower?? Any help
Well every moment it gets lower as it tries to equal out with the humidity in the air, but any significant drop will be months. However 25% isn't so bad, you'll have to leave the door open slightly longer at the start maybe to get a good start. Just make sure you burn it hot and check your chimney every once and a while. My first season was 25-35%. I would split and test every piece then mix the lowest stuff with the worst to try to get the average moisture content as low as possible.
I also put a large box fan facing down the stack inside, and then a dehumidifier at the end... however whether this accomplished anything is up for debate. But it made me feel like I was doing something about it lol.
Right now I have it all stacked in one of those pop up sheds. Hopefully it gets better soon.
Not sure what the burning season is like where you are, you using this year? So long as it's not one of the denser woods (oak etc) it'll be great next year.
But I'd pull up the sides of that shed so the air can get at it and just use it as a roof to keep the snow/rain off it.
If you got room in your furnace room it should be pretty low humidity in there with low humidity and good air turnover. You might try stacking some of your wood in there, all criss cross like a Pilgrim. Check it after one week but plan on having to check it again after two weeks...
Is that because the wood was frozen when you tested it outside? Fresh splits tested with a moisture meter are meant to be tested well above freezing, I think 70f. If I was to test my wood with my MM I would bring it in the house and warm it up. How long your stack will take to dry depends on many factors. If you have access to some dry pine you will be set. Also some construction cut offs would help. Good luck Libbynuke, it will get better with proper planning. Start thinking of future seasons now.
