Typically a flush or nearly flush insert wants 24" to the mantel. If the insert projects they want 30-36" from the stove top. The further the mantel projects into the room, the higher it needs to be. All inserts require different clearances, you really need the owners manual..
What height above the insert does the manual call for?
Not as far as clearances are concerned. It will however greatly reduce the lifespan of the tv. Probably the worst place ever for a tv!Does a TV above come into play?
I know it's warmer there, but it's so wild that it's winter there and summer here.
We tend to forget the other half of the world, from South America to Africa to Australia and New Zealand.
Strongly disagree.
Most (all?) inserts have blowers that blow air out into the room. This air is warm, and rises. It depends on how strong your blower is, how big your room is and how high the ceiling, but many combinations (like mine) lead to cool air falling from above the insert completing a room cycle of airflow. This makes above the insert the best place for a TV. Measure and see - YMMV. A tissue ribbon can be useful for subtle airflow detection.
That's an interesting observation on convection. With our (now gone) fireplace the masonry behind the wall heated up the wall notably. If you put your hand on it after the fire had been burning for hours it was warm. This was with an uninsulated liner in the chimney. Best place is debatable. I prefer the screen to be a bit lower. It's easier on the neck.
