Andre B.
- Oct 25, 2006
- 391
Eric Johnson said:All my rads are piped bottom to bottom.
If you're concerned about the plugs breaking the radiator casting when you try to extract them (steam rads tend to corrode while hot water rads usually don't), there are other, more labor intensive ways to get them out safely. Specifically, chemicals, heat, drilling--in that order. I've had a lot of luck with a drill, hacksaw blade and a cold chisel.
I once worked on an 1 1/2 plug in a radiator for a few hours before it turned.
At which point I realized it was a left hand pipe thread.
