Base for Pellet Stove
nin28
9
Pennsyltucky
We're looking to buy a pellet stove pretty soon and I have hardwood floors. I was wondering about what type of base to put under it. Can I buy something pre-fab? Is there something I can put down that pretty easy? Not so concerned about appearance. Thanks for any advice.
You can buy a hearth pad (do a search here) and you will see some great home built pads. It's easy to do with cement backer board or plywood covered with 12 " tiles.
Ok, I picked up the plywood and cement board and have gone to work. It's going to be pretty basic. I have leftover tiles from a foyer we just redid, so I'm using those. I have everything cut up, now just have to lay the tiles. Just have to pick up some molding for around the edges. Thanks for the help.
If you are placing the pad on a wood/tile floor you may want to stick some of those
"Magic Sliders" on the bottom of the plywood and measure the width of the moulding accordingly.
It makes sliding the pad very easy if you need to get to the back of the stove without scratching
the tile.
Best move I made.
Brian
You know, when I attached the cement board to the plywood, I had tiny nubs from the screws sticking out the plywood. I was thinking of putting some sort of felt underneath, but those sliders might do the trick. Of course I would completely cover the felt with the hearth pad. Thanks for the idea Brian. Did you get them at Home Depot?
I had the same problem with the screws. I used a dremel tool to grind them off.
HD, Lowe, and many hardware chains carry those "sliders". They are not cheap,
but work very well. Use enough to spread out the weight of the stove and protect the floor. I think I used about
fifteen or so to do my 4 X 3 pad.
I also liquid nailed a couple of 2 X 4's cut to fit, to the bottom of the stove and used that stick on felt to protect my slate
if I should need to move the stove only.
Brian
http://picasaweb.google.com/briangkeaveney/20080921Stove?authkey=PLu7aT9_v1A#5248823101394450290
