I just had interesting thought
crazy_dan
857
Missouri
started a load of clothes in the dryer, got on the computer and in a few min. I was feeling cold which was kinda weird since I was sweating a few minutes ago in the bed.
here is what I did since getting up
went in to kitchen which is where the stove is opened the air up to get it ready for a reload
looked out at the thermometer and it was about 16 outside so I reloaded the stove
put the clothes from the washer in the dryer and started the dryer
got on here for a few min and noticed my feet were really getting cold
that is when it hit me our electric dryer vents outside this old drafty house and wondered how much air it draws did a little google search 150 CFM did a little math and every load of clothes pulls every cubic foot of air out of my house no wonder my feet were getting cold :)
so I reached a solution in my head to get one of those lint traps for venting the Electric clothes dryers in to the house, the goals of this are
1. keep the heat in the house
2. add humidity to the house (we/the wife runs a humidifier) so I am thinking this may very well get rid of this thing.
Do you see a problem with this?
I have an electric dryer and the house was started in 1856 and added on to a few times so it is FAR from being air tight.
Here in Pennsylvania we just built a home and it is against code to vent a dryer into the living space of a home, into the attic, into the basement, or into the garage. There are strict codes regarding the venting setup, including how much flex pipe may be used, I think it was no more that 6 feet of flex, and how many elbows the vent pipe may make prior to exiting the home.
Your case may be different, but this ole' boy ain't ventin' his dryer into his home.
I once noticed the humidity and heat build up in my home in the winter and found out the vent hose on our dryer fell off and all that heat was not leaving the house.It will add a good amount of heat into the home but i don't really know if there are any health hazards to doing this!Ditto on it being a code violation.MY wife rarely uses the dryer these days except for the coldest or bad weather outside!shes a close line addict.Here's an idea!!How about designing a vent hose with radiator fins so the dryer still vents to the outside but some of the heat will be vented inside.
I'm not sure on your setup but I wonder if you could attach some form of cold air feed and whether it would make a difference. For instance, open a vent to your attic so air needed would be pulled from that space when in use but closed during nondrying times. I'm not sure how a dryer pulls air, in other words is it randomly from all over the machine or is there one input somewhere. If there was an input, you could simply hook another vent which would pull air. Our laundry room is pretty small and has a door. Our attic access is also in the laundry room so if this idea proves to make sense, I might be doing some retrofitting.
Neat thought!
Tripper
The wifes mom and dad also vent inside their house with their clothes dryer, and their house (3 side earth-contact) is a lot newer and more airtight than mine. So I will give it a whirl and I can always put it to venting outside if I need to.
DO NOT vent a gas dryer into your home! That is a no - no!
We have an electric dryer so we do vent into our home.
There a no codes here against venting an ELECTRIC dryer into a home - I've done it for years but only during the winter as I love the increase in humidity at that time of year.
Picture this: Snuggle in for family night at home with a nice fire glowing, homemade brownies just baked & being served and the dryer adding humidity to the house. Doesn't get any better than that!
Shari
We've done it in the past, but only with an electric dryer. Also, we used our dryer very little.
I would definitely say it might also depend upon the size of the house and where the dryer is located. And for gosh sakes, WATCH THAT LINT. That is a great fire starter, so be very careful if you see a bunch of lint gathering.
As for my wife, she hates using the dryer and really fights it. I'm the only one who will use it here. The wife prefers to just use the heat from the wood stove to dry her clothes or hangs them on the outdoor solar dryer whenever possible.
Glowball Worming Bustierre said:
Neat thought!
Tripper
dryer creates slight vacumn which relieves itself from easiest access. ideally, air would come from nearest point to dryer intake so that house heat wasnt airwashed BUT humans need air to breathe! READ MY LINKS BELOW!
I went through your links but didn't find anything directly related to this topic. I did find some interesting info on bringing outside air to a woodburning stove which was an idea I was planning on experimenting with but I don't really see the point after reviewing one of your links. While houses certainly need to pull air from the outside, I don't believe that anyone ever considered a dryer to be an integral part in that need. With that being said, designing a closed loop induction and ventilation system for a dryer may just help keep some of the heat in your home, especially in an older home where replenished air isn't an issue.
Edit:
Since there are two different topics being discussed here, I wanted to add that I don't mean to vent your dryer into your home. I am more concerned with both pulling and venting the dryer air on the outside of a house.
Chris
I've seen houses destroyed by mold, mildew, and rot because of too much humidity. A house leaks in both directions. Cold air infiltrates if there is a negative pressure inside caused by consuming appliances and by what's known as stack effect. Leaks also let out humid air due to stack effect. That humidity then condenses on the cold side of the insulation. That is why most modern homes have a very well sealed vapour barrier and air to air heat exchangers. It is said that one unsealed electrical outlet can condense up to six gallons of water into the wall over the course of the winter.
I would never vent a dryer inside a house. The money you save in heat probably won't pay for the damage it may cause.
I just happened upon this thread, but I completely agree with LLigetfa, the previous poster, you should never direct vent ANY drier into a home. You can rot the roof of your home from the inside. Think about it, how much heavier is a wet load of laundry compared to a dry load? I don't know off hand, but if it is say about 8.3 lbs., than that is a full gallon of water that you are sending from your dryer into your home every time you dry. It will find the 1, 2, 3, or even 10 coolest spots along the exterior of your walls inside of your siding, or more likely your attic, before it decides to condense. Do this every day for say, a year, and rot will occur. We are not talking about a small amount of vapor.
Just not worth it.
How is the humidity from running a clothes dryer a few times a week going to cause all this terrible rot, when people run humidifiers all winter long in an attempt to put a little moisture BACK into the house when running their stoves 24/7?
-SF
Just pull the vent line to the dry loose from where it exits the house and put a piece of panty hose over and let if blow the warm air in the house.
I stalled one on my dryer.
Got rid of the flex pipe & ran solid. Runs down into attic, put a "T" at end of the the vertical drop, one end goes outside the basement wall, the other end 4' pc of stsright and the vent box with filter on end. Puts heat in unheated basement,
its so dry here the moisture won't make a dent, plus dehumidifier in basement anyways. The rest goes out the vent to outside. Works ok. Dryer don't run enough to really do much. Maybe a couple days on weekend. But figure I'll take the free heat in the basement when it is running. Clean the filter about once a week. Just glad to get rid of the flex which always collects a ton of crakp and that is more of a fire hazard than anything.
There are a pile of articles and pictures in fine homebuilding about what happens to the inside of walls when you do this. The pictures usually have wood with holes in them and black fuzzy stuff all over the inside. Building science, home inspection magazines and on and on and on.
the water condenses inside your walls. If you are running an OAK and you have to pump water into the interior, where is the water going? Its moving outside through the walls, around the kick plates past the electrical outlets.
Then again I really do like the smell of my detergent....
If you happen to have a high RPM washer, your clothes will be MUCH lighter and quicker to dry in the first place. I highly recommend one to those still using the inefficient beasts of yesteryear. Second, if you are interested in saving money by not paying the utility company to blow air that has, essentially, been heated thrice, once by the stove and once by the dryer, and then the cold air coming into the house to replace the twice heated air that's being blasted outdoors......
Simply dry them on a retractable line not too far from the stove. It's worked for us for years.
We sometimes give ours a quick tumble with a dryer sheet to soften 'em up.
Peace,
TS
I vented mine to the garage and stopped after two loads of laundry. Too much moisture at one time and it all condenses on the coldest spots. Just a bad idea.
NOW - how about just hanging your clothes to dry in the house - in the room with or near the stove?? So it takes a day - it is better than running the dryer right? How is that for GREEn?!
Yup. That's what my wife does.
well some thoughts after venting dryer in the house for a while.
1. Not as bad as everybody says. I have a huge 4'X8' single pane window about 10' from the dryer and if we do 2 loads only a day that window does even get condensation on it.
2. The house does not get frigid when running the dryer
A side note/question
What is the difference from letting clothes hang and dry in the house vs using an electric dryer vented in side? forget the electric used the same washer is going to leave the same amount of water in the clothes and if they dry inside the the same amount of water vapor is released in the house. It kinda seams like 6 one way 1/2 dozen the other.
A heat extractor from the vent to heat water....Just a thought
The problem with a heat reclaimer is going to be condensation. The air leaving the dryer is going to be close to saturated through most of the cycle. If you remove the heat, you will get condensation. This will pick up lint and then clog the vent. I have had to clean out too many dryer vents running through cold crawlspaces.
Most houses will need humidity in the winter to keep things comfortable. I have experimented around and found that one load a day into a ventilated space is not too much, but we tend to do laundry in batches of 4-5 loads at a time. I've thought about an automatic damper, but I doubt that it would do much most of the time. I'm keeping it outside for now.
Chris
I vent my electric dryer into my attached garage. The vent hose in the garage is aimed into a 5 gallon pail that has a couple of inches of water in it to collect all (hopefully) the lint. I've been doing this for 3 1/2 years without any problems.
I do the same but only when i need the moisture.
