Dark Smoke from pellet stove Englander 25-EP outside vent
mike2rach
28
PA
We are having issues with our Englander 25-ep; We have called Englander about a month ago to have some help with this, but it doesn't seem to have changed. The 1st thing that the tech person thought was wrong is that it was on the wrong setting on the control board. It was set up to burn corn and this stove only burns pellets. Ok so that was changed but still nothing has changed with the smoke coming out the pipe, our siding is black from this and my husband is very upset about this. So we are looking for help; what could be the issue?
Our pellets aren't wet they are stored in a dry basement. Help!!!
Any Suggestions anyone else have this issue or is this normal, really hope not. We've only have the stove up and running since Thanksgiving.
did this just? start if it did then clean the stove .if it has been doing it from the start you have an air to fuel problem it cloud be over feeding or not getting enough air
this has been doing this from day one. I will have my hubby call them again to see if they can adjust the air, the 1st thing that they did work on to try and fix was that it was getting to many pellets because of it being on the wrong setting from the factory, it seemed to be ok for a day or 2. Once this is straightened out then we have to figure out how to clean the cream colored vinyl siding that is now black along with the sofiting(sp)
My hubby cleans the stove everyday so we already know that is not the issue.
if the feed is right you may be able to take a voltage reading on the blower and see if it is runing right.
Are you actually getting visible smoke from the vent? or is just the residue on the siding? what is you venting configuration?
you can actually see the black smoke coming from the vent, I will have to ask my husband about the configuration
