LeonMSPT
"Always"? is pretty often.
What if there is no creosote down low to ignite? But the person burns a very hot fire which keeps the lower part of the chimney and the pipe burned clean? However, the top part of the chimney, sticking out into the 30 below air up high, cools enough often enough to accumulate some measure of creosote? One day, it gets "just hot enough due to the hot fire... 650 degrees or so, and it has enough air, it'll ignite.
I have fought some chimney fires over the years. Seen the chimney plugged high, burning like a torch. Go up there and drop the weight on the chain, throw in the "goody bag", and let things cool off. Sometimes you have to put two or three bags in, because it keeps flashing back into flames...
When it's cool enough, we'd clean it and check it over. Either tell them, "Go ahead and fire it back up.", or "It's condemned, don't fire it until it has some work done on it. It's not safe." Should they decide to fire it anyway, their insurance company is unlikely to cover their losses.
"Always", is the opposite of "Never"... neither really exists in our lives.
Carbon_Liberator said:MacPB said:Does anyone know how a chimney fire starts?
Does it always start from the stove pipe and move upwards?
Can it start in the top of the chimney from a spark?
If you're stovepipe and most of the chimney is very clean, but some creosote has accumulated near the top roof exit or on upper elbows, can it still happen?
Thanks
I think chimney fires always start lower down and progress upwards. I don't see how it is possible for the heat and flames to pass by and not ignite the creosote build up on the lower part of the flue and ignite it further up.
This is my understanding of how a chimney fire can start and can progress under the right circumstances. Somebody correct me if I'm wrong.
Creosote accumulation it is likely to form mostly near the top, coolest part, of your chimney, but if you burn cool fires and/or damp wood you will also get accumulations in the stove pipe closer to the stove. (If you have black build up on your glass you are getting it in the lower part of your chimney).
The thicker (most dangerous) accumulation of creosote are generally out of reach of the heat that goes up the flue, but the lower part is not. If you burn hot enough you will not get any significant creosote deposits near the lower end of you chimney (stove pipe), but if you burn cool fires coupled with moist wood you can and will get deposits in the lower parts of your flue. If you get enough deposits and burn a particularly hot fire those deposits in the lower portion can, and will, begin to ignite. Depending how thick the creosote deposits are, how hot your fire is, and how long you let it burn for will determine what happens next.
If you have relatively thin deposits the creosote will likely just burn off and you won't even know it is happening.
A medium deposit may start making a lot of popping and crackling that you may hear, and it will progress up the flue (towards the thicker deposits), this is when it would be a good time to close your damper all the way as it is still basically being sustained by the fire in the stove, and likely this will be enough to starve the progression of the creosote from being burning off.
If the deposits are not that thick the last sort of "chimney fire" will often go out on it's own accord as it progresses up the chimney away from the heat of the stove, however if your creosote deposits are thick enough, and it is able to burn far enough up your chimney, and your stove fire is burning particularly hot, and the damper is wide open allowing plenty of extra oxygen to flow up the chimney it can start to become self sustaining and literally create it's own real fire and draft and you then have a full fledged chimney fire on your hands.
