Gooserider
Mod Emeritus
As LL said, it is to late for priming at this point - the system is filled... What SHOULD have been done, as with any hydraulic system being put into service, and what should be done any time the system is drained to the point where the pump is empty, is to pull the engine over without starting it, so that the pump can fill itself with oil. In order for the pump to fill, you have to give the air in it someplace else to go, which you do by holding the valve in the right position to move the piston in the cylinder (usually the extend position, but it all depends on where the wedge is when you start)...
When the pump fills up, it will start compressing the air in the system, and you will get a bit of movement in the wedge, it is OK to start the engine after this.
Usually this will take 5-10 pulls - if you have a stiff engine, it may help to pull the plug in order to get rid of the compression loading, but that just makes it easier to turn over.
Once the engine is started, you should then cycle the wedge all the way up and down several times to purge the air from the system - if there is air in the system, the piston movement will be very jerky (keep body parts clear), as the air purges it will smooth out - when it runs up and down smoothly, stop the engine and check the hydraulic fluid level, you will probably be a couple quarts to a gallon low - this is the amount that lives in the pump, cylinder, and other plumbing.
Since the pump is normally lubricated by the hydraulic fluid, starting it up without priming is one of those mystery abuse situations, where you have probably done some level of damage to it, and shortened it's life, but how much is really an unknown... However there is no real way of going back, so you will have to live with it, and note that the pump may still last a VERY long time...
Gooserider
Gooserider
