Ahhh...starting in early this year. The old "glass cleaning" is one item where the horse has been beat to death, ground up for hamburger, cooked, served, run through the garbage disposer, .... well, you get the picture. A few threads for light reading:
balls for cleaning hot glass!
https://www.hearth.com/econtent/index.php/forums/viewthread/31616/
Again- How to keep your glass on your wood stove clean
https://www.hearth.com/econtent/index.php/forums/viewthread/31227/
How Do You Clean Your Pellet Stove Glass When It’s Hot?
https://www.hearth.com/econtent/index.php/forums/viewthread/29531/
Clean glass with news paper
https://www.hearth.com/econtent/index.php/forums/viewthread/29305/
Idea for cleaning inside of glass
https://www.hearth.com/econtent/index.php/forums/viewthread/25282/
Glass cleaner
https://www.hearth.com/econtent/index.php/forums/viewthread/22806/
glass cleaner
https://www.hearth.com/econtent/index.php/forums/viewthread/16328/
Cleaning glass window on door of woodstove
https://www.hearth.com/econtent/index.php/forums/viewthread/16008/
Any tips on how to keep glass clean?
https://www.hearth.com/econtent/index.php/forums/viewthread/15583/
Breckwell BigE/Cleaning glass
https://www.hearth.com/econtent/index.php/forums/viewthread/10069/
Insert or stove glass cleaner
https://www.hearth.com/econtent/index.php/forums/viewthread/12865/
Stove Glass Cleaner
https://www.hearth.com/econtent/index.php/forums/viewthread/9287/
Cleaning hot door glass
https://www.hearth.com/econtent/index.php/forums/viewthread/6767/
Need Recipe for door glass cleaner
https://www.hearth.com/econtent/index.php/forums/viewthread/6231/
Door Glass Cleaning: Anyone Thought of…
https://www.hearth.com/econtent/index.php/forums/viewthread/3943/
Clean that Glass…
https://www.hearth.com/econtent/index.php/forums/viewthread/3816/
Glass cleaning Techniques
https://www.hearth.com/econtent/index.php/forums/viewthread/2933/
Glass Cleaning Periodicity
https://www.hearth.com/econtent/index.php/forums/viewthread/726/
Cleaning Glass – while it’s hot?
https://www.hearth.com/econtent/index.php/forums/viewthread/509/
Cleaning Hot Glass?
https://www.hearth.com/econtent/index.php/forums/viewthread/154/
Culling through all the posts, you’ll find several recommendations – including, but not limited to: (roughly in order of ‘most mentioned’ to least…[ ] comments are mine)
Moist newspaper dipped in ash [works well except for heavy black deposits]
Windex with newspaper or paper towel [works a little better on heavy black deposits]
White Vinegar/water w/ newspaper or paper towel
Damp paper towel
Damp rag
Rutland Stove Glass Cleaner
Formula 409 [good for heavy black deposits]
Mr. Clean Magic Eraser
Burn stove hot – what ever is on glass just comes off [good for heavy black deposits]
Castrol Super Clean [good for heavy black deposits]
Bottled Water w/ paper towel [one of our ‘high class’ woodburners?]
Fast Orange hand cleaner (without pumice)
Orange citrus cleaner/degreaser
Easy off oven cleaner [haven’t tried, but should work VERY well...you can also cut butter with your chainsaw!]
10 tablespoons of ash + liquid hand soap, stir to make paste, scrub on glass with toothbrush
Toothpaste or soap and baking soda
Razor blade [be careful not to scratch ceramic]
Spit on newspaper/towel, dip in ash
Rutland White Off
“any type of alcohol” on a rag [just be sure the stove is out!]
“some sort of stainless steel sponge thing”
“my soggy wet underwear” [no clarification on what they were wet with, but I’d hate to think what you could come up with if you’re looking for a cheap source of ammonia]
