I need some help from all the building code experts. I need to know if it is possible for me install my Jotul Oslo in my current prefab chimney so that it will meet code. Here is what I currently have:
My house is about 4 years old and has a wood-framed chimney that contains a double wall pre-fab chimney pipe. It runs about 35 feet from the basement ceiling to about 3 feet past the top of the roof. The inner pipe is 8” stainless steel, the outer is 12” galvanized. The pipe has never been hooked up to a stove or fireplace before. The problem is that the pipe is only UL-127 (1700 degrees, I think) approved for use in a factory manufactured wood fireplace insert. The pipe was apparently designed to be used with a DESA International (DESA seems to be owned by FMI now) factory prefab fireplace only, but the pipe was actually installed with the incorrect assumption that it could be used for a wood stove. The Jotul Manual says the pipe must meet UL-103 to be used with the Oslo.
So I was hoping that my installer could run a 6” or 5.5” flex pipe like Duraflex or Foreverflex inside the 8” Stainless steel DESA pipe. However, I was told this does not meet code - which may very well be true. If I can’t run the flex pipe up the 8” DESA due to code, could I remove the 8” DESA pipe and run insulated 6’ flex pipe or something else inside the 12” galvanized? I have been told this wouldn’t meet code either.
Is there anything I can do to make it so I can install my Oslo so that it meets code without having to pull both the 12” and the 8” out and start from scratch?
Here is a link to the pipe that is currently installed:
Http://doitbest.com/Chimney+Components-Desa+International-model-48-8DM-doitbest-sku-400881.dib
Top view here: https://02c20fd.netsolstores.com/index.asp?PageAction=VIEWPROD&ProdID=4675
Sorry for the long post... and thanks in advance for the suggestions.
