I'm just starting to compare add-on wood furnaces. Install will be easy enough, already have the details worked out for a new insulated 6" flex liner, but a little worried that the run will be a little long (>30ft) but I've seen woodstoves with 35 foot runs before, just wasn't sure about such a large firebox mating up with that long of a run for that far.
There are a lot more options than I figured there would be, and a lot of specs to examine when I compare them. geesh, who knew it could be this complicated.
Currently, I have a 100,000BTU gas that is 92% efficient and it can't keep up when it's windy and cold (test this week was 40mph gusts when temp was in single digits; results had house hold around 66 degrees with wood stove cranked and a number of electric heaters running throughout the 3500ish sq ft house.) The attic and wood stove room aren't ducted, so the furnace wouldn't heat them no matter what.
Let's just assume that I'm gonna heat 2500-3000ish with this furnace.
it's triple wythe soft brick with lath and plaster right on the brick inside. It's 2 stories with a finished attic on the top of that. it's 150yr old, and I'm working hard to restore the 150 year old windows to their former glory with hand made wooden storm windows.
here are a few of the choices I've run accross:
Vogelzang 2500
115,000BTUs
24" logs
? cu ft
1100CFM blower
$1200
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_1036726_1036726
USSC 1537G
119,000BTUs
26" logs
? cu ft
twin 500cfm blowers (1100)
$1300
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200395370_200395370
FC500
100,000BTUs
22" logs
5cu ft
1150-->1500-->1800CFM blower
$1799
http://www.woodheatpro.com/fc500.aspx
USSC 1400
114,000BTUs
26" logs
? cu ft
twin 550CFM blower(total 1100CFM)
$1964 (manufacturer) probably cheaper at store ~$1400 or so
http://www.usstove.com/proddetail.php?prod=1400
Ashley 1602R
135,000BTUs
28" logs
? cu ft
1,100-->1,250-->1,400 CFM blower
$1900
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200362036_200362036
Comments? suggestions? man, with one of these giong I'd be sure to go through 10 cords of wood at my place. I better decide soon what to get in case I have to process that much for next year...
Vogelzang 2500
115,000BTUs
24" logs
? cu ft
1100CFM blower
$1200
USSC 1537G
119,000BTUs
26" logs
? cu ft
$1300
FC500
100,000BTUs
22" logs
5cu ft
$1799
USSC 1400
114,000BTUs
26" logs
? cu ft
Ashley 1602R
135,000BTUs
28" logs
? cu ft
$1900
