What is the degradation temp for Pex? I know it says on it... 200 at 80 PSI. Does this mean it can go to 250 at 40 PSI and still hold up? At what temp( and or psi) does it cause damage? Has anyone done an experiment to find out? OR have a guess?
it didnt seem to, but im sure it didnt do it any good.rowerwet said:does the pex shrink in diameter as well as length?
sgschwend said:G, yep those to data sets don't match very well. The only other data point I found was the melting temperature which was higher than the graph would project. I hope you can see why I mentioned the practice of testing the settings.
I was hoping we could see how tough Pex is, it is just not as tough as copper and steel, even though it is tougher than some solders.
Thermoplastic materials loose their strength to pressure and tension with increasing temperature.
The table below can be used as a guide to common thermoplastics and their derated strength with temperature.
Manufacturing data should always be consulted.
Code:Derating Factor Temp PVDF CPVC PVC PB PEX PE (oC) (oF) 21 70 1.0 1.0 1.0 1.0 1.0 1.0 27 80 0.9 1.0 0.9 1.0 0.9 0.9 32 90 0.9 0.9 0.8 0.9 0.9 0.9 38 100 0.8 0.8 0.6 0.9 0.9 0.8 43 110 0.8 0.8 0.5 0.8 0.8 0.8 49 120 0.7 0.7 0.4 0.8 0.8 0.7 54 130 0.7 0.6 0.3 0.7 0.8 0.5 60 140 0.6 0.5 0.2 0.7 0.7 0.4 66 150 0.6 0.5 1) 0.7 0.7 0.2 71 160 0.5 0.4 1) 0.6 0.7 1) 82 180 0.5 0.3 1) 0.5 0.6 1) 93 200 0.4 0.2 1) 0.4 0.5 1) 104 220 0.4 1) 1) 1) 1) 1) 121 250 0.4 1) 1) 1) 1) 1) 138 280 0.3 1) 1) 1) 1) 1)
1) The thermoplastic is not resistant for long term service at this temperature. Operating conditions should be avoided.
PVDF - PolyVinylidene Fluoride
CPVC - Chlorinated Polyvinyl Chloride
PVC - Polyvinyl Chloride
PB - Polybutylene
PEX - Cross Linked Polyethylene
PE - Polyethylene
sgschwend said:That reminds me I did see a graph earlier that showed the loss of strength over time. It was kinda cool, I made me feel like it was what note #1 was all about. The engineering tool box has typical data, it suggest looking at manufacturer's data. Have you ever found any of that?
here is the link:
http://www.polyprocessing.com/pdf/technical/Crosslinked Polyethylene with OR-1000 System.pdf
Max. working Durability in continuous working conditions
temperature pressure
up to 60°C 140°F 10 bar 145psi 50 years
60°C to 80°C 140°F to 176°F 6 bar 87psi 50 years
80°C to 95°C 176°F to 203°F 6 bar 87psi 10 years
