25-PDVC question
tommy24a
28
PA
I am in the process of giving my stove a good cleaning. Removed both blowers and will replace gaskets. I have a question on the auger motors. Is there suppose to be play on them in and out wise? I can move the top and bottom auger mortors in and out about 3/4 to 1" on the shaft..almost seems like the whole auger goes in and out.....normal?
mine do that, I think it might aid in not having a jamb.
If you mean pulling the auger output shaft outward, away from the auger body, yes, there is supposed to be some play. As long as they turn w/o any play in the gears (rotational play), they should be fine.
