webbie
Seasoned Moderator
heaterman said:Sand is a better medium for insulating than conducting. They make firebrick out of the stuff........??? just sayin.........
They make rockwool from rock and fiberglass from glass (sand).......but the original rock and glass are terrible insulators.
It's not the material, but the form it is in........which often creates the insulation. In these cases, it is often the air which does the insulating.
As to thermal mass, it always depends......if there is somewhere else for the heat to go! If a mass of floor is over wood framing within the envelope of a house, it would seem that the heat must either go into the home or back to the boiler (return water, etc).......
But when concrete is poured over earth, it might lose a lot of heat to the ground....etc.
I think part of the rule of thermodynamics is that it has to go somewhere......mass can even out the transfer (like soapstone).
