2-stroke mix for a 6401
Beetle-Kill
1,849
Colorado- near the Divide
Just got home with the new 6401. Actually reading the manual, and I come across this- 50:1 if using Makita oil, 40:1 when using other oils. Why?
Because Makita likes to give the impression that their oil is sooo much better than the others.
Any modern 2-cycle chainsaw oil from a saw maker (Stihl, Husqvarna, Dolmar, Echo) should give you no problems at 50:1. Use full synthetic and you'll notice cleaner parts when you finally have to tear down the engine.
Thanks. I've got a bunch of Stihl HP Ultra, sounds like I'll be good to go. I don't anticipate a tear down anytime soon. JB
yep, what he said. just do whatever. i'd do 40:1 probably. On my older Stihl I like to use 25:1, keeps the mosquitoes away, and that way it uses the same thing as my cheap china saw.
Keep in mind... Check your spark plug color... less than 50:1 will lean out your fuel to air mix.. If running 40:1 or less you may need to richen up your carb...
50:1 with any premix oil will be fine. I've never heard of anyone smoking a piston due to burning 50:1 premix.
I burn 40:1 simply because I mix 5 gallons at a time and it makes the math easier (one pint in a 5 gallon can).
+1 to this. I had to tweek mine just a hair when I went with a different mix. Got tired of dealing with multiple gas cans of different mixes. Now I only have two.
Milling I run 40:1 and cross cutting 50:1 stihl ultra but may change do to price.
change from Stihl ultra? or change ratios? I have just been using generic synthetic and am happy with that. You saw a LOT more than I do, though.
For me, it makes sense to stick with Stihl Ultra. In addition to my saws, I also run two Stihl 4-mix trimmers. The 4-mix engines really do need Ultra to keep them from gumming up (it's not just a marketing gimmick).
Word is Woodland Pro from Baileys is made by the same factory as Dolmar and Echo.....it's what I'm using now.
Glad to hear I am all in! Cant justify stihl anymore with a 42oz tank.
Wacker Corp did some 2 cycle oil testing years ago & gradually leaned out the oil till the mix was 200 to 1. There were no failures & no piston scuffing. They then straight gassed the engine & it seized very quickly. They also said at that time there were 2 or 3 2 cycle oil manufacturers in the US & everybody had their own dye & labels, Randy
That's interesting. Do you have a link to that testing? I'm curious about the 34:1- to 50:1 variation, if any.
No, This is just a service manager of a large rental fleet who was involved with the Wacker testing, telling me this about 12 years ago. 2 cycle engines haven't changed much so results should still be valid, Randy
No sweat, I was curious if my 011 would be OK with 50:1, just would make it easier on mixing. My 346 and 6401 should be OK. Thanks, JB
All saws are fine with a good quality modern two stroke oil at 50:1, although I run about 45:1 and a little seafoam. Anything richer than 40:1 and the carbon deposits will become evident.
Yeah I was gonna strain a bottle of Ultra, gotta be gold or diamond flakes in there.
Make me sick evertime I am on my las couple bottles. 14 inch .043 chain and a 6 pack was over 35.00! Use to order from Baileys a lot. Need some more milling chains now to.
Brands ratios are good. lol Stihl is way to much.
The key with Bailey's is placing big orders....... wanted to buy a set of their piston ring compressors for $7.99....... shipping was $8.99. I don't think so.
