Thanks to the Forum for sharing. Because you all took the time to chat with me - you provided me with enough information/courage to just be plain honest with my installer - and now I will get my block plate with the insulation and we have determined that the Napoleon 1402 - will likely not fit under the second lentil and we have the wrong stove. I have made 100 strides in the right direction because you took the time to share your expertise with me.
Now I get to go back to looking - anyone have any ideas for an insert - I need to clear two lentils - so the connector point to the flue liner needs to be back at least 10 inches from entrance to the fireplace and I only have about 23 inches height for an opening....(these two items kick out most stoves) I so far have seen the voyageur, the Quadrafire 4100I, Colonial TR004 and one I have never heard of before the Solution 2.0-I insert (that appear will work). Any ideas would be welcomed.....BUT TRULY - Thank-you for taking so much pride in your profession that you provide this avenue for regular consumers like myself. I hope others find you just as helpful. Good day - Seaturtle.
