.050 vs .058 Gauge Bar & Chain
ManiacPD Posted By ManiacPD, Jan 21, 2009 at 4:57 PM
Thread Status:
  1. ManiacPD
    ManiacPD
    Member 2.
    NULL
    Jul 1, 2008
    199
    0
    Loc:
    Maine
    I'm getting ready to purchase a new Husky and would appreciate if someone could give me the pros & cons on the different gauges of bar/chain combinations.
    Thanks in advance for your help!
  2. ManiacPD
    ManiacPD
    Member 2.
    NULL
    Jul 1, 2008
    199
    0
    Loc:
    Maine
    OOPS, wrong Forum...
    Mr. Moderator, please bump me over to the Gear Room...thanks...
  3. fossil
    fossil
    Accidental Moderator 2.
    NULL
    Staff Member
    Sep 30, 2007
    10,550
    2,421
    Loc:
    Bend, OR
    As you wish, Master. Rick
  4. fyrwoodguy
    fyrwoodguy
    Feeling the Heat 2.
    NULL
    Dec 11, 2008
    344
    0
    Loc:
    eastern central NH
    i would suggest running .058 gauge saw chain.there is much less chain stretch.and when the guide bar becomes worn,you can up grade to .063 provided the bar rails are the same height and NOT an UNEVEN HEIGHT. with .050 there is the most chain stretch,hemce chain derailment occurs more often.
    laminated guide bars are a good learning tool,but no replaceable roller nose,and limited life span.original equipment on most saws.
    solid one piece w/ replaceable roller nose guide bars are the best.
  5. jdemaris
    jdemaris
    New Member 2.
    NULL
    Oct 11, 2008
    452
    0
    Loc:
    Central New York State
    The thicker the drive tangs, the more metal contact area and less wear on the sprocket - but not by much.
    I was going to buy a Husky awhile back, but refused it because the dealer only had the .058" bars. Not for me, but my reasons are specific. I don't hand sharpen anymore and I have about 20 chains - all 3/8" .050 or .063 in 16", 20", and 32". If I dull a chain, I take it right off and install another. I machine sharpen later. Mostly big Stihl saws. When I was shopping for a new saw, I wanted to make sure I could swap chains back and forth. If the Husky had an .050" or .063" bar, my chains would fit. Dealer only had .058". So, I didn't buy it and got a Makita Dolmar instead. I'm glad now I did. It's a fantastic saw. Came with two 72 link - 20" .050" chains.
  6. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    .050 is the new standard not as wide as the 58 but cuts a little faster
  7. ManiacPD
    ManiacPD
    Member 2.
    NULL
    Jul 1, 2008
    199
    0
    Loc:
    Maine
    Thanks to all who replied. I couldn't imagine .008" would make much difference but I wanted to check for sure.
    Thanks again,
    Paul
  8. jdemaris
    jdemaris
    New Member 2.
    NULL
    Oct 11, 2008
    452
    0
    Loc:
    Back in the late 60s and early 70s, the Stihl saws used .063" gauge chain on just about everything. I assume because they used 3/8" and .404 and the .404 only came in .063" at the time. This way, the same bars worked with either. Now, it's not so easy to find .063" 3/8" chain. Also, I often grab the wrong chains, it gets confusing. An .063" chain doesn't fit an .050" bar very well unless it's really beat up and worn.
    If everything was .050", all would be just fine and a lot easier to figure out (in my opinion).
  9. ManiacPD
    ManiacPD
    Member 2.
    NULL
    Jul 1, 2008
    199
    0
    Loc:
    Maine
    I guess I'll go with the .050 then. No worry about mixing chains as the new saw will have an 18" or 20" bar, and the 345 is a 16".
    Thanks
Thread Status:
