    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Presa canario New Member
    Central, pa
    Totally forget how to set the stove up to learn the wireless remote....
    Isn't there a hi/low range that you have to switch off w/ this stove?
    #1
    Helpful Sponsor Ads!
  2. imacman Minister of Fire
    Hope you still have the stat owners manual.
    As for the Hi-Lo setting, I don't know if that's necessary for the remote stat to work, but if you forgot how to set it, here's the procedure:
    Press off button....allow stove to shut down on it's own.
    Then unplug it, and then plug back in. Within 5 seconds, press both down arrows and release. This should show what mode you're in....if it shows H L, then quickly press the down arrows again, and it should switch to O O.
    Let the lights on the control board to go out, and then re-start the stove.
