2004 25pdv
Jimrig Posted By Jimrig, Dec 12, 2013 at 5:08 PM
Thread Status:
  1. Jimrig
    Jimrig
    Member 2.
    NULL
    Feb 12, 2009
    24
    0
    I have two 25pdv one a cottage the other in a home.They are both 8 years old .the one in the cottage when I open the door and remove the ash from burn pot.than close door in a few min's it go into e3 over heat.yet it will burn all day and nite as hight as I set it
  2. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    how much fuel does it load up before it gets going again good after you close the door?
    strikes me you are hovering close to the high limit anyway when you get ready to do this and the added loading without draft is pushing you over the high limit. check the room fan make sure its not clogged, also if this doesn't work, reset the mode into mode setting "d" which will unlock the room fan control from the heat range , run the blower speed higher than the heat for a bit before you scoop so the stove will cool down a bit before hand
  3. JHASS
    JHASS
    Member 2.
    NULL
    Dec 29, 2008
    123
    14
    Loc:
    Jersey Pines
    The manual for the unit I use in my shop says the E-3 is a blower failure not over temp.
    11. Unit keeps shutting down
    (“E” codes on control board)
    1. Blocked flue (E-1)
    2. Blower failure (E-3)
  4. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    blower failure will cause E-3 but trust me, its a high limit error code its a very common cause for E-3 but not necessarily the only reason
  5. Jimrig
    Jimrig
    Member 2.
    NULL
    Feb 12, 2009
    24
    0
    hello mike been a long time.After I let it COOL ABOUT 10 MIN'S IT START RIGHT BACK UP.have the room fan on 9 stove is on 3
  6. bill3rail
    bill3rail
    Minister of Fire 2.
    NULL
    Jan 12, 2012
    650
    127
    Loc:
    LI, NY
    Did you remove ALL of the ash from the burn pot?
    If I remove ash while the stove is burning, I will leave a lot of embers to keep the fire going.
    Bill
  7. Jimrig
    Jimrig
    Member 2.
    NULL
    Feb 12, 2009
    24
    0
  8. Jimrig
    Jimrig
    Member 2.
    NULL
    Feb 12, 2009
    24
    0
    when I take the ash out of burn pot.I have a metal spoon that I run under the fire and the ash will stay on the spoon.when I'm done I still have a fire.i have done it the same way for 8 year's.this just started. thank u for the input
Thread Status:
