https://www.hearth.com/econtent/index.php/forums/viewthread/34241/
I have the insert from the above thread. We've used it without issue for years but this fall/winter I'm not getting the same performance. For as long as I've lived here, when we use this thing, the room (Den) gets so hot you almost barely stand to be in the room. The doors between this room and the next ( Kitchen) were removed almost as long as the inserts been in there. Half of the kitchen even got some heat. There is no door only an island between that half of the kitchen and the dining room part of the kitchen, and I cannot remember if that other half got heat. It was giving us so much heat we were thinking about a door or one of those above doorway vents between the room with the insert and the room on the other side of the wall between the den and kitchen. But for whatever reason it is simply putting out nowhere near that much heat this time. I don't think I ran it last year. Maybe I'm not operating it the same way. I assume the fire is hot enough. Maybe the blower isn't kicking out as strong. I attached the thermometer I clip inside my BBQ grill to test for temp and the temp inside seems pretty hot. At times well over 300. Even when I attach it to the vents there is some pretty hot air blowing out. I don't think I've measured less than 150 coming out of there, though the right side does seem to blow a little less intense and at a slightly lower temp than the left side.
I thought about replacing it at one point, but there's no point if the new one isn't going to be putting out like or more than this one. I've checked and made sure I don't have air from outside getting in, and I'm were pretty good from a weatherproofing standpoint. Even with a electric space heater in same room the temp is only getting up to a lightly comfortable level. I'm not sure if the thermometer on the heater has measured the room to be over 74 yet
