    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
346xp with 20"?
Post in 'The Gear' started by ampamp, Mar 19, 2012.
  1. ampamp Member
    Buffalo - Rochester
    Done a lot of homework on this and have gotten a 50/50 response on if this combo would work. I do a log load or more of hardwood primarily for firewood. I'm use to a 450, 18" bar full chisel. It does bog down a bit, but it seems to work pretty well. I seem to get into larger stuff and that's seems to be the case with the standing trees espeically. Either way, could a 346xp swing a 20" bar? I can get a 357xp at 10% off list....which seems like a good option and a great saw......it's just that bottom line I'm talking a few 100 bucks more. You guys have been a great resources. Looking forward to the comments.
    #1
    Helpful Sponsor Ads!
  2. smokinj Minister of Fire
    Anderson, Indiana
    Yes a 346 should pull it fine. No record speeds but if its half the saw they say it is, it should pull it off!
    Scotty Overkill likes this.
  3. Dairyman Feeling the Heat
    Southwest MO
    It'll pull it fine, I'm running a 18" on mine and she screams. If I was to go bigger I'd jump to the 562.
  4. kenskip1 Member
    Coleman Texas
    As long as you are pulling a 325 and not a 3/8 chain you should not have any problems,Ken
  5. mayhem Minister of Fire
    Peru, MA
    Husqvarna rates the 346XP to pull a 20" b&c. Have at it!
  6. MarkinNC Feeling the Heat
    Leicester, NC
    That's what mine was wearing when I bought it new but I switched it to a 16" bar for more speed. I think a 346 with a 20" bar would work fine as a solo saw that will do most of everything. If you have the bar buried in oak, it's not gonna cut as fast as a big saw, but it will do it. That pro saw should have a nice long life span compared to lesser units.
    Mine did not wake up for a few tanks of gas. It's a noticeable difference IMO. The Stihl 261 is the equivalent and is supposed to be an awesome saw as well.
