5.5" Liner Kit
ponyboync Posted By ponyboync, Jul 30, 2009 at 4:48 PM
Thread Status:
  1. ponyboync
    ponyboync
    Member 2.
    NULL
    Jul 12, 2009
    109
    0
    Loc:
    NC
    Looking to purchase an HI300 and all the dealers are using 5.5" liner kits in their quotes. Isn't the HI300 designed/tested for 6"? Are they trying to make it easier for the install?
  2. Wet1
    Wet1
    Minister of Fire 2.
    NULL
    Apr 27, 2008
    2,529
    9
    Loc:
    USA
    It sounds that way... what's the ID of your flue?
  3. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    And the height?
  4. ponyboync
    ponyboync
    Member 2.
    NULL
    Jul 12, 2009
    109
    0
    Loc:
    NC
    ID is 12" and the height is about 23'. The damper width is about 5 9/16".
    Thanks.
  5. Wet1
    Wet1
    Minister of Fire 2.
    NULL
    Apr 27, 2008
    2,529
    9
    Loc:
    USA
    You don't want 5.5". With that stove in that flue, you want a 6"... preferably insulated 6" (especially if it's an exterior chimney). You'll have to take the damper out, notch it, or ovalize the liner to get through the damper, but this is normal.
  6. ponyboync
    ponyboync
    Member 2.
    NULL
    Jul 12, 2009
    109
    0
    Loc:
    NC
    Yup, that's what was thinking. But everyone kept using the 5.5" in there quotes. I'll just make sure I get the adaptor and purchase the liner kit somewhere else.
    Thanks.
  7. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    If that ID ix 12X12 then you will be fine with 6". But those people quoted 5.5" inch for a reason. And probably a reason we are not seeing from these posts. As to 5.5" in 23' exterior masonry chimneys I have burned into two of them for the last three years and they draft like a vacuum cleaner. And I am north of you. They will do fine in a chimney that height in NC.
    Heck, member Todd in Wisconsin is using one and like me has almost too much draft. And none of ours are insulated.
  8. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Just noticed that you have an Isokern so you have a twelve inch round chimney.
  9. Wet1
    Wet1
    Minister of Fire 2.
    NULL
    Apr 27, 2008
    2,529
    9
    Loc:
    USA
    Sure they are, to make it easy for them to install it. They probably haven't even come out to his house to see his chimney...
  10. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    If it was just one that is what I would suspect. With several quotes suggesting it, where there is this much poop there must be a pony. And with that fireplace being an Isokern it is a rare breed of cat. Anybody I know would come to see it first just to see one, much less see what they are quoting.
  11. drdoct
    drdoct
    Feeling the Heat 2.
    NULL
    Jan 24, 2008
    431
    0
    Loc:
    Griffin, GA
    With my 5.5" liner I never had to cut anything... just dropped out the damper and it fit right in... tightly but still moving through without ovaling or anything. If I were an installer, I'd probably go that route but not with that high a chimney... I would think it may be hard to open the door with it going full speed. Well maybe not but you get my drift.
  12. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    True dat. With both Todd's and my 5.5" liners you can open the stove doors an inch or so and let go and they suck the door closed. I think these 5.5" suckers, because of less surface area to dissipate heat, stay hotter and create a heck of a draft. In at least three stoves.
  13. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    True dat dat. 5.5" is a great option for a ID 6.5x10.5" flue tile since a 6" liner is very snug.
  14. bsa0021
    bsa0021
    Feeling the Heat 2.
    NULL
    Oct 1, 2008
    406
    5
    Loc:
    Ohio
    I just got two different quotes for a Hampton HI300 one using a 5.5" flue and the other 6". If I understand you guys...I can go either way???
  15. drdoct
    drdoct
    Feeling the Heat 2.
    NULL
    Jan 24, 2008
    431
    0
    Loc:
    Griffin, GA
    If a 6" liner will fit easily, then I would suggest a 6" liner. I've got that small flue tile so I HAD to use the 5.5. It works great and I've only got 17' on it. I've still got to buy a 5.5 brush. If you've got 23' and room for a 6" then that should be a very ideal draw on the chimney, especially if it's an interior chimney (like mine). I had called around to all the stove shops and noone had even heard that there is a 5.5" liner. I live in the South though and our stove shops are horrible. Surprised everyone is quoting you that which is just the opposite from what happened to me. BTW, putting the liner in is very easy. I would consider it if I were you, you'll save a few hundred dollars and maybe a thousand. Good luck.
  16. ponyboync
    ponyboync
    Member 2.
    NULL
    Jul 12, 2009
    109
    0
    Loc:
    NC
    Hey drdoct. Thanks for the help. The chimney is interior like you said and I think I will try to install it myself. I'm always trying to save a buck. I was just curious why they quoted the 5.5". I guess the adaptor will work for either or I need to specify.
    Thanks.
Thread Status:
