50:1 gas in a can??
Sean McGillicuddy Posted By Sean McGillicuddy, Mar 11, 2013 at 7:09 AM
  1. Sean McGillicuddy
    Sean McGillicuddy
    Feeling the Heat 2.
    NULL
    Jan 7, 2012
    445
    163
    Loc:
    Easton Mass. not enough time in NB Canada
    I saw cans of pre mixed 40:1 and 50:1 fuel??
    Has any one used this yet?
    Interesting idea. Too early on Monday morning to think of looking @ prices.
    Sean
  2. Thistle
    Thistle
    Minister of Fire 2.
    NULL
    Dec 16, 2010
    4,206
    2,234
    Loc:
    Central IA
    Very expensive. About $7 for the quart can at Lowes I noticed recently.My big Husky holds about 31 ounces & gets pretty thirsty in big wood.I couldnt afford that.Mixing a gallon or 2 at a time is easy & so much cheaper.
    TreePointer, PapaDave and MasterMech like this.
  3. BobUrban
    BobUrban
    Minister of Fire 2.
    NULL
    Jul 24, 2010
    1,922
    1,136
    Loc:
    Central Michigan
    x2 on pricy stuff. I use it to store saws but not to run them daily. Because I am a seasonal cutter my saws sit idle for months at a time. When I know I am done cutting for the season I will drain the gas and run them dry. I then add some of the pricy mix in a can stuff and run a little of that into the saw. I just think they set better with good gas that has no ethanol in it.
    TreePointer, gmule and MasterMech like this.
  4. MasterMech
    MasterMech
    Guest 2.
    NULL
    Uber pricey if you run more than a tank or two a year through your saw. Intended more for seasonal equipment that doesn't get used much.
    It's good fuel, but not really affordable when you burn a couple gallons a month or more.
  5. Bigg_Redd
    Bigg_Redd
    Minister of Fire 2.
    NULL
    Oct 19, 2008
    4,153
    995
    Loc:
    Shelton, WA
    Anyone who can't figure out how to mix gas (which is the crowd these products are aimed at) probably ought not have a saw. Or any other power tools. And should probably turn in his man-card.
    Thistle, swagler85 and Wildo like this.
  6. MasterMech
    MasterMech
    Guest 2.
    NULL
    The stuff is a real boon when used in BobUrban's example to store equipment. Not everybody has the option to buy ethanol-free gas to store their equipment with.
    Yes, it appeals to the crowd who doesn't want to mix their own fuel, but for most everybody with 2-cycle power equipment, the fact that it won't F up your carburetor's rubber bits over time is a benefit to both mind and wallet.
  7. Bocefus78
    Bocefus78
    Minister of Fire 2.
    NULL
    Jul 27, 2010
    538
    173
    Loc:
    Just Outside Indy
    I have ran 1 can of the premixed stuff in my toro powerlite snowblower (was out plowing and the sidewalk guy left my 2 gal can somewhere--gotta love the help lol). The blower ran great! I wouldn't buy it again, but it did save me from buying another can that I dont need!
  8. slindo
    slindo
    Member 2.
    NULL
    Mar 14, 2008
    171
    28
    Loc:
    Maine
    Yeah, you are missing the point. The point being not that the gas is premixed with oil but that it has no ethanol.
    My life has gotten a whole lot simpler since I started making my own ethanol-free gas. It's like 1965 again when you could put away a saw or mower with gas in it and be confident it would start in a couple pulls come spring. That's worth a couple dollars to me, so I may stop making my own (it's messy) and start using the premix - for the last tank of the season at least.
  9. RK_MacKendrick
    RK_MacKendrick
    Member 2.
    NULL
    Dec 8, 2012
    56
    77
    Loc:
    NW CA
    That is all I use, CA gas is poisonous and eats everything, including the old Fords carb.
    My McCullochs love it.
  10. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    There is another twist to this. I was having problems with our weed whacker. Saw guy suggested I buy a quart of it. Not to run the thing, but to clean it out. After done weed whacking, get all the gas out. Pour in a few ounces of this pre-mix and start it. Run until it runs out. It has been working nicely. Never had problem with the saws so don't use it there; just on the weed whacker with the little tiny engine and no doubt very small jets.
    BobUrban likes this.
  11. MasterMech
    MasterMech
    Guest 2.
    NULL
    I've been mixing my shop gas with Star-Tron and equipment that has been sitting all winter with fuel in the tank has been starting up and running just fine. No fuel issues in any of my personal equipment or any of the stuff sitting around waiting for me to get to it.
    I'm afraid if I started using the pre-mixed stuff or SEF for the four-stroke engines, I'd go broke with the fuel costs. $30+ a gallon....
  12. nate379
    nate379
    Guest 2.
    NULL
    I'm glad we don't have that ethanol crap.
    I don't bother with messing with anything before storing it. Throw it in the shed and that's it. The generator I have sat 15+ years and it fired up on that gas.... don't know how, that stuff wouldn't even light the trash in my burn barrel when I dumped it out.
    Someone threw an empty can of the Stihl mix in my truck, I noticed it's 93 octane. We odon't have that up here.
