Jacob said:I am wondering if it affects draft very much to put an adapter going from 6" to 8" right off the stove?
Jacob said:and 178 dont make sense. thats greater then 1.5 times. and from 28 to 50 isnt 1.5 times. (if that makes sense)
countrybois said:It MAY work, but everything you can find on the topic will tell you NOT to increase the flue diameter as it WILL negatively affect draft. You can go from 8" to 6" but not from 6 to 8.
So....that is text-book. Do what you like.
Jacob said:Im realy not trying to argue with anyone. Im just wondering if those that have done it had good luck or bad. if nothing else ill just find myself a new stove with an 8" hole. no biggy, just less of them out there.
BrotherBart said:countrybois said:It MAY work, but everything you can find on the topic will tell you NOT to increase the flue diameter as it WILL negatively affect draft. You can go from 8" to 6" but not from 6 to 8.
Pray tell what "text book" or anything else for that matter says that it is OK to neck down a flue to a smaller size?
