    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. denisn New Member
    oregon coast
    hi, i have a 1983 non cat insert i bought new. its burned 10 month a year 24 hr day since 1983 uses 4 cord per year and heat s great. i just bought a 1984 used for son but it has a bunch of extra crap inside think its the cat type. SHOULD I GUT IT ALL OUT?? thanks denis
    #1
    Helpful Sponsor Ads!
  2. bogydave Minister of Fire
    So Cent ALASKA
    A 1984 model. I don't know when they came out with the catalytic.
    I would not modify it.
    If it is a Cat model, don't burn trash, just untreated wood.
    If you want to burn trash, junk mail etc. & it is a cat type, you should be able to
    remove the catalytic piece easy enough, or it may just burn out if trash is burned.
    Modifying it may cause problems you don't foresee, & effect the burning & safety of the stove.
  3. Todd Minister of Fire
    Lake Wissota
    I wouldn't gut it, it will be much more efficient with all the guts inside but you also want to make sure it's all in good working order. May need new parts.
  4. cmonSTART Minister of Fire
    Antrim, NH
    :bangs head against wall:
