I have a Summer's Heat (England Stove Works) 50-SNC13 and I'm in my third season of burning. I have a few observations and questions which I would really appreciate any input on that I can get.
It's taken me awhile to get used to the stove and its qualities (actually still learning) but I think I'm getting better. I burn mostly ash with some silver maple mixed in and though I try to get very seasoned wood (have to purchase occasionally because my cuttings run low) I'm sure that it is not always the case. Regardless, I seem to get nice clean burns with almost no residue or build up in the chimney, almost no smoke (ever) from the chimney top and no smoke buildup in firebox, or backup into the house. Here are my questions:
I am assuming that I get a good draft due to the clean burn, no smoke aspect - I can clearly see flames and startup smoke being pulled up in the firebox. Is it a safe assumption to believe that I have good draft?
The air intake on this stove is just the one operated by a small rod at the bottom of the unit. There are times when I need to leave the damper open all the way for a good part of the burn-day if I want to keep a strong burn going. Cracking the door slightly always seems to get things going really well, but with door closed and damper more than halfway closed, sometimes the fire seems to struggle (air starvation?). Is this a by-product of intake, draft, or both?
Also, I have no flue damper installed (it wasn't recommended by manufacturer), though I do have a brand new one should I choose to install it. What are the pros and cons of having a flue damper with this unit? I'd have to remeasure but I'm thinking my chimney is about 18 ft.
All-in-all this has been a pretty nice burning season. I probably burn about 12-16 hours a day and have had no issues. I just would like to know a little more about draft vs intake and what I can do to be most efficient.
Thanks.
Thanks.
