precaud said:With the Quad 2100M (1.5 cu ft.) I get 7 to 9 hours every morning; it would be longer if I packed the firebox full for the evening's last load. The key to extending burn times is cutting off the air supplies - all of them - and only allow enough "bleed" air into the firebox for the coals to burn down at the desired rate.
Are your temps getting down to like 250 range when you do this?
Are there visible flames?
Do you get your stove blazing before you shut her down?
So you close your air intake AND your flue damper all the way? (You may not have a damper i guess)
Does your glass get all sooted up when you smolder burns like this?
