Accentra rebuild from cast to brown enamel
zrtmatos
352
Connecticut
How hard would it be to replace the cast iron outer parts on a Harman Accentra with brown enameled parts? I currently own a cast iron Accentra model from 2006 that works well. I found a 2003 brown enameled model for sale at $1200 and am thinking I would like to swap them. The brown model has some non-working parts, auger motor I think. Would this be an easy upgrade? I tinker with my stoves now and have serviced everything on them now; from annual cleaning including fan rebuilding to ignitor replacement. Anyone try this at home?
Well the outside cast parts are the inside parts.Just buy the stove and swap the parts you need to make it work.But 1200 is on the high side,I think.
Yes, Rock Tavern. Don't go and swipe it from me.
So can those enameled panels be swapped easily?
No.The whole stove will be taken apart to do this,as they are not seperate panels,they are the body of the stove,which is why I reccomended fixing it,even if you use your other stove for parts.
Reactions: zrtmatos
Don't worry...I was about to tell the guy "sold!" but the exhaust outlet is way too low for my vent setup. Looks to be in great shape though. Good luck!
The seller removed the listing. They figured out the problem it had and are now going to sell it for 2K. Too much for me on a 2003 model.
