Good evening,
I have a couple of questions concerning extending an unused flush-to-crown terracotta liner about 12".
I currently have (3) 13x13 terracotta flues, one unused, and other two for fireplaces. The two for fp's extend about 8-12" above crown and capped. The unused was built flush to crown. The unused flue will be used as a chase for an SS flex liner for an oil boiler.
The following questions concern high wind, freeze/thaw/water penetration, draft/backdraft, and best practices:
1) Do I need to extend the terracotta to match the other flues, for either draft, or SS liner top plate connection purposes? Can I just mount the top plate and cap to the Crown (w/silicone or mortar) without the problems listed above?
2) If I need the small extension, can I attach to existing teracotta with high temp, all weather silicone, along with top plate/cap/flex liner? If not, can it be done with mortar instead of silicone? If not, any other "easy" ideas?
Thanks for your time and help.
