I've been reading quite alot about woodburning & chimney dynamics from several sources. Some say that chimneys installed "outside" of your "heated" house can cause problems. My chimney install is straight up from my stove but most of it (beyond the 1st 3 feet) is exposed to the outside because of my install.
My stove/chimney install is in a single story great room (700sqft w/ cathedral ceiling) attached to a two story main house. The layout made it necessary to have about 10 foot of chimney above my roofline (to clear my second story & maintain the 10/2 rule). I used DuraPlus triple wall insulated 6" chimney (Simpson/Dura-Vent). Stovepipe is DVL double wall (about 7ft length above stove) connecting to the chimney pipe.
Is it necessary or even beneficial to further insulate or box in my DuraPlus manufactured chimney? It drafts fine, I have no issues starting a fire, maintaining a fire or having a good & complete burn each time (so far). My typical burns are 400 to 600 degrees (stovetop thermometer) depending on how full & often I feed the stove.
