Where can you get a BK princess brand new for $1925?On stove cost, the base princess costs the same as the base IS brand new at my local stove shop. The nc30 still costs less than half as much at 800$.
I think the IS cat is same as Fireview cat, but not completely sure. But, here is the Fireview cat size from a post I made some time ago (https://www.hearth.com/talk/threads...a-blaze-king-ultra.145687/page-4#post-1998469).Pretty sure they are not twice as big.
Hmmm... Not quite double I guess then!?!I just measured the cat in my IS. It's 9.5 by 5. That's 47.5 square inches . I can't check the depth because it's pretty hot and can't remove it without burning myself. It's all one piece and not two cells like the fireview.
Sorry BeGreen, but there is still an efficiency rating even in high burn rates. Multiply the thermal efficiency (HHV) at the high burn rate times peek Btu's. What counts is what stays in your home...not what the stove generates.Wouldn't it also be burn rate? If the BK tops out at say 50KBTUs/hr and the 30NC is being forced to burn at 90KBTUs/hr, efficiency is not in the equation. That is like saying a Prius in not efficient because it only gets 30mpg at 95mph.
Which is precisely what is not happening in the barn. There simply is no comparison for fuel consumption with taking a cold large space and all it's content up 20º or more as compared to maintaining less cubic ftg. at a steady temp. Swap out the stoves and the BK will be eating wood quickly and the 30NC much less so. Is the BK more effiicient? Yes, but 5% increased efficiency does not account for the difference in heating load the stoves are achieving.What counts is what stays in your home...not what the stove generates.
Rain is good for the winter wheat. Enjoy it while it lasts and hope we don't get a repeat of last summer's drought.
Actually, this has nothing to do with quality. Only trying to determine the correct cat sizes. I cannot speak to the quality of the cats. I've tried going down this road once before and found that the truth is a difficult thing to find. One will say the truth is here, one will say the truth is there.Actually, you folks are forgetting that size only matters if all else is equal.
I was concerned about that too but the story is actually pretty funny. The cat costs more because it is much bigger. Cost is proportional to size. See, when you want to build the most efficient stove you need a bigger cat.
Canister Measures 9.75 x 5.25
BK King 5.0 x 10.5 = 52.5
BK Ashford 4 x 10.6 = 42.4
WS Fireview (4.7x4.7)x2 = 44.18
Looks like double to me! That is actually a pretty funny story after all!
Here are some BK cat sizes from the condar site
View attachment 172255 View attachment 172256 View attachment 172257 View attachment 172258
Look again please, then tell me what you see.All that effort and no consideration for thickness? Welcome to the third dimension,the important one.
You're right. Seems to be about the same volume of cat for less money. So every five years or so you will save 100$ on a cheaper replacement cat.
Forgive me. Just having a bit of fun busting your chops. Sometimes the devil rules me.You're right. Seems to be about the same volume of cat for less money. So every five years or so you will save 100$ on a cheaper replacement cat.
I am as a boy walking down life's path carrying a pouch of stones. As I approach a hornet's nest, a mysterious force compels me to throw a stone at it. The same mysterious force controls the swarming hornets, yet they perceive it not. I so love the mysterious force, just as it does the hornets.
I've had my fun. Time to put my stones away for a time and head down my path.Please bust them.
Please bust them. You actually only save 50$ on the fireview vs. The princess and the princess cat includes the stainless can and a new gasket so it is reasonable to pay a little more. The op isn't looking at a fireview. How does the IS compare?
It has everything to do with price. I can buy from an overseas supplier a cat of identical dimensions for 1/4th the price. Please accept the fact that this is what we do. One stove manufacturer uses the overseas cats, their margins on resell are superb! In all testing done by cat stove manufacturers it comes down to price versus particulate destruction.Actually, this has nothing to do with quality. Only trying to determine the correct cat sizes. I cannot speak to the quality of the cats. I've tried going down this road once before and found that the truth is a difficult thing to find. One will say the truth is here, one will say the truth is there.
Did somebody says hornets nests?
So that's the new challenge, hum.....I love reading from the fan boys on both sides!
I've never seen 30hrs out of my princess, 24hrs is easy during the SS but means nothing this time of year.(1 full load and almost full load right now) If I had NG heat when I started burning wood in 09 a low burning stove would mean very little. Maybe this year I'll tap this NG they brought out last year then maybe my stoves low burn ability will mean less, well...ahhh probably not!
If I was buying a stove today the decision may be more difficult but I could never see swapping from a Princess to another stove currently available. Should a stove clearly better than my Princess come out I'd own it at the start of next years heating season.
I love the Ideal Steel also and will probably pull the trigger on one this spring. The Blaze King will be my second choice if I change my mind and only due to price.
Lot of mud slinging on burn times between the IS and the princess but IMHO they really arent significantly different. First, for every BK owner that says 30+ hrs burn time is easy, there is another that says it is far fetched.
Look at posts on different forums and you will find IS Beta testers that acheived 24-30 hour burn times under optimal conditions and others routinely getting 18-20 hours.
So if you take away all the "My-stove-is-better-than-yours-chest beating", it seems there might be a realistic 4-6 hr difference with BK winning. SO the BK guy will have to load his stove 7 times a week in the shoulder season and the Woodstock guy 9 times (whoopee doo!!)
