Advice on concrete/stone work for hearth
fran35 Posted By fran35, Jan 11, 2012 at 5:56 PM
  1. fran35
    fran35
    Member 2.
    NULL
    Jan 10, 2011
    157
    3
    Loc:
    PA
    Hey folks,
    I have 5 x 9 area behind my wood stove that I want to install some decorative stone/lick-em stick em rocks to. The wall is in the basement and is concrete block that has been painted. In order to work with the mortar and rocks, I realize I need either the pain off of the wall or hang metal lath with a scatch coat. I am wondering which way would be the easiest and most cost effective way. Also, what is the best way for me to remove enough of this paint to get the mortar to stick to it? It is in a finished basement, so pressure washing is out of the question. Thanks
  2. firebroad
    firebroad
    Minister of Fire 2.
    NULL
    Nov 18, 2011
    1,521
    512
    Loc:
    Carroll County, MD
    Have you considered hanging wallboard as a "canvas" for your stone and mortar?
  3. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,651
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    +1. Screw some durarock or Hardi backer to the
    wall & have at it with your veneer.
  4. fran35
    fran35
    Member 2.
    NULL
    Jan 10, 2011
    157
    3
    Loc:
    PA
    Thanks guys. Really wishing I had never threw pain on the block.....
  5. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    +2 this is what I was thinking also. The paint might not be a bad thing, especially if it's a moisture blocker.
  6. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    + another.
    I personally like HardiBacker better because it has neater edges and is lighter.
  7. fran35
    fran35
    Member 2.
    NULL
    Jan 10, 2011
    157
    3
    Loc:
    PA
    Should I glue or use adhesive between the block and board? or just concrete screws?
  8. firebroad
    firebroad
    Minister of Fire 2.
    NULL
    Nov 18, 2011
    1,521
    512
    Loc:
    Carroll County, MD
    it would depend on the size and weight of the materials. Of course, a few generous beads of construction adhesive wouldn't hurt.
  9. ironpony
    ironpony
    Minister of Fire 2.
    NULL
    Jan 22, 2010
    2,069
    585
    Loc:
    mid-ohio via St.Croix USVI
    I would frame it out with 2X4's, cover it with duroc and go with that
    reason being
    you will be able to use corners (stone) so you will have the thickness
    which will make it look like real stone, as opposed to stone glued to the wall flat
  10. pyper
    pyper
    New Member 2.
    NULL
    Jan 5, 2010
    491
    1
    Loc:
    Deep South
    And if you did fur it out with 2x4s you could put insulation behind it.
  11. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,651
    1,200
    Loc:
    How good does adhesive hold to paint?
    Probably not gonna make much of a
    difference...
