Alternative containers for maple sap buckets
Burn-1 Posted By Burn-1, Mar 12, 2008 at 2:43 PM
Thread Status:
  1. Burn-1
    Burn-1
    Feeling the Heat 2.
    NULL
    Jul 13, 2006
    446
    1
    Loc:
    Lakes Region, NH
    It looks like it could really be a great sugaring year here in NH with nearly perfect weather so far.
    I have a few trees I would like to tap to make just a small amount of syrup and I have the spiles but no buckets. It looks like the buckets would get expensive quickly although I would always have them in the future. Has anyone used anything else to useful effect. Would a 1 gallon milk jug work OK if I checked morning and night? I'm hoping to get some tubing and plastic spiles in which case I'll use a 5 gallon carbuoy but that's not looking good at the moment.
  2. EatenByLimestone
    EatenByLimestone
    Minister of Fire 2.
    NULL
    Jul 12, 2006
    5,666
    600
    Loc:
    Schenectady, NY
    milk jug, cottage cheese container... 5 gallon bucket. The larger the container the better since you do not have to empty them as often.
  3. Burn-1
    Burn-1
    Feeling the Heat 2.
    NULL
    Jul 13, 2006
    446
    1
    Loc:
    Lakes Region, NH
    I had thought about a five gallon bucket but wasn't sure if a nail could hold the weight if it got too full. I think the milk jugs will have to do for now.
  4. EatenByLimestone
    EatenByLimestone
    Minister of Fire 2.
    NULL
    Jul 12, 2006
    5,666
    600
    Loc:
    Schenectady, NY
    I've used the milk jugs, but drove by the house with the 5g buckets DUCTAPED to the tree!
    LOL!
    Matt
  5. Cazimere
    Cazimere
    Member 2.
    NULL
    Oct 29, 2007
    226
    2
    Loc:
    Delmarva
    Use rope to tie the bucket to the tree by its handle.
  6. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    I've been using 5 gallon buckets for years with the handle hooked right to the spile, never had a problem. Not sure what kind of splie you use, the ones I use have a hook that hangs down.
  7. homebrewz
    homebrewz
    Minister of Fire 2.
    NULL
    Nov 29, 2005
    1,052
    75
    Loc:
    East Central, NY
    I have used plastic 5 gal. carboys (water cooler jugs), milk jugs, and 5 gallon buckets. I use spires made from sumac branches,
    and slip the plastic tubing right over them and down into the buckets. That way, they buckets can sit on the ground.
    btw, I don't make much syrup, but the sap makes excellent beer!
  8. MainePellethead
    MainePellethead
    Minister of Fire 2.
    NULL
    Dec 9, 2007
    904
    0
    Loc:
    Southern Maine
    Many around here use milk jugs as well.
  9. lvfd50
    lvfd50
    New Member 2.
    NULL
    Oct 1, 2007
    66
    0
    Loc:
    Livonia NY
    Beer from the sap now that sounds good. I was just starting to look into making my own beer and was wondering how you use the sap in your beer making? Also what kind of flavor do you end up with?
  10. homebrewz
    homebrewz
    Minister of Fire 2.
    NULL
    Nov 29, 2005
    1,052
    75
    Loc:
    East Central, NY
    I use the sap instead of using water. Its basically water from a tree with a 2% sugar content.
    The sugars in the sap ferment out increasing the alcohol content somewhat. It gives beer a crisp,
    clean sort of "woody" taste. If you let them age, the mapleness usually comes out.
    Also, if you need 5 gallon buckets, most supermarket bakeries have them lying around. They are
    usually willing to part with them for free. Donut filling, frosting, etc comes in them. You can also get
    them from the deli, but those are usually pickle buckets, and you will need to soak them in a strong
    bleach solution for weeks to get the smell out!
  11. Gooserider
    Gooserider
    Mod Emeritus 2.
    NULL
    Nov 20, 2006
    6,737
    10
    Loc:
    Northeastern MA (near Lowell)
    Minor tip on the 5 gallon buckets - If you are getting ones with lids, make sure the bucket and the lid are from the same manufacturer The buckets look standard, but they aren't, there is just enough subtle difference in the way the rims are sized and shaped that a lid from bucket company A will probably not fit or seal properly on a bucket from company B... I have tried to keep my buckets all the same brand as much as I can, and use a Sharpie to mark the brand clearly on the side of each bucket and lid so I can match them up easily - especially important to mark the buckets as the brand imprint is usually on the bottom, hard to check on a full bucket!
    Gooserider
  12. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Just started running yesterday here in the Twin Cities, MN. A lot of work for a pint or two! Good news is the new pellet camp stove works great for boiling down and is tons cheaper than LP.
  13. mikeathens
    mikeathens
    New Member 2.
    NULL
    Jan 25, 2007
    648
    0
    Loc:
    Athens, Ohio
    My neighbor uses sumac branches with a 1 gal milk jug hung right on it - drill a hole in the jug. I use metal spiles with galvanized bag hangers and blue 3-gallon bags. Kinda pricey from Lehmans.com, but they work great.
    A friend at work uses the standard spiles, gets food-grade tubing, and sticks it on the end of the spile. He has 5-gallon buckets with a small hole in the lid to stick the tubing in.
    As far as pickle buckets, I have several of them. Still smell like pickles 3 years later. I have never had any off-flavor from it. I also have a 15-gal. barrel that had schwepps syrup in it that I use for storage.
Thread Status:
