Finally pulled the trigger today and got the last Magnolia my local TSC had. I have had my eye on this for a few weeks and thanks to wkpoor's reviews, I had to have it. Plans were to remove legs and put a smaller set on them to fit into my masonary fireplace area. After buying the stove and getting it on the floor in the living room, I started looking closer. Due to the layout of the living room, I decided I would rather have it sitting in the corner about 5' from fireplace and run the stovepipe into the flue above the fireplace area. It would be more of a "viewing pleasure" in the corner. I then went outside and took a closer look at the chimney. It is approximately 16' tall and is made with double row brick with a clay liner in the top 8' or so. As I looked at it, I noticed cracks in the mortar joints between the brick in several areas. It is about 30 yrs old and I am not too excited with it's structural integrity now. I also noticed that in the area where the thimble would go thru, there is about a 2" gap between the siding and the edge of the brick.
Because of this and the fact we would enjoy it better in the corner where we could see it, I then considered alternatives. The easiest resoluton was to install a direct vent triple wall Dura-Vent chimney going thru the ceiling about 4' from the exterior wall. I have never seen one up close but had a good idea of how it worked. Because of this, I found an installation manual online about it and started reading. In a sense, there is a little more to it than I thought, but not beyond my ability. As I started looking further into it, I didn't think $200 for the ceiling kit would be too bad, until I realized the pipe wasn't included. I found that it would cost me around $400 for the ceiling kit, black pipe from stove, and 2 sections of triple wall for attic/roof. In all reality, I probably need 3 pieces of the pipe, so that would bring it up another $100.
After thinking about it, $400-500 is more than I really want to put into 30 pounds of steel and fiberglass. Are there any other alternatives to this piping that someone could suggest? I am not afraid to fabricate this myself, as long as it is safe and cheaper. Thanks.
