Am I being paranoid???
crawfish Posted By crawfish, Sep 9, 2009 at 3:46 PM
Thread Status:
  1. crawfish
    crawfish
    43
    2
    Loc:
    central pa
    I did a self install of a Napoleon 1402 wood insert with the help of a friend back in April and am now wondering if I might have done something wrong. What concerns me is where my friend joined the SS Liner to the Low Clearance Adapter at the stove. You see, the liner would not fit inside the adapter so he made a couple of small snips in the liner and slipped it down over the adapter and used several self tapping screws to secure it. Is this a normal practice? It isn't real clear in the owners manual how to make this connection but I'm wondering if maybe I wasn't sent a some sort of connector to do this properly. Also, after I thought of this (and before my friend filled in some missing bricks we had to removed to gain access) I put two 1/2" band clamps around the connection and cinched them up good and tight for assurance. My biggest concern is that if creosote forms could it run down and leak out over the top of the adapter? Please tell me I am overreacting because I hate the thought of having to tear apart the bricks again!
    Tim
  2. MountainStoveGuy
    MountainStoveGuy
    3,654
    2
    Loc:
    Boulder County
    no, your not overreacting. That connection is not what we call "drip less". The liner should fit inside the adapter, not on the outside. I would order the correct part from your dealer to make that connection. There should be a liner connector from the liner manufacture that will take the corrugated liner end, and convert it to a appliance adapter.
  3. Wood Heat Stoves
    Wood Heat Stoves
    1,905
    14
    Loc:
    Nevada City, California
    a pair of hand crimpers, or needle nose pliers, and/ or a flex adapter would have helped...
  4. KP Matt
    KP Matt
    118
    0
    I think it's neurotic, not paranoid - unless you think you are being persecuted by your insert :)
    In these matters a dose of neurosis is appropriate.
  5. gpcollen1
    gpcollen1
    2,027
    11
    Loc:
    Western CT
    You should have installed the proper adapter or tucked that liner inside. I would redo it, preferably with the correct adapter. Could you have zero issues with this setup - yes, it is possible...
Thread Status:
