Another tiny blue flame problem - Jotul Allagash
DavidS77
11
Connecticut
I started up my Jotul GF 300 DV Allagash for its sixth season of light use and the flame was no more than a third of the usual height and all blue. The manual said that this may be due to too much air flow, and to reduce the airflow I should move the stud under the stove back. However it was already as far back as it would go. A serviceman came and spent two hours and was unable to make any improvement. Any ideas?
Remove the burner pan & with a 1/2" (or 13mm) wrench, remove the burner orifice. You will probably find a spider's nest behind it. Looks like a white diaphragm. Use a pipe cleaner or a Q-Tip to remove it. Reassemble & you should be good to go...Lemme know it the problem persists after this procedure...
