Antique Cast Iron Gas Insert, Can it be used safely??
ThreshHawk
1
Kansas
Hi all! Recently purchased a home built in 1928 that has a really cool cast iron gas insert in the basement fireplace. The gas line was long ago disconnected, but it still runs into the firebox, it has just been capped. I often restore antique cast iron cookware, tools, etc., so I believe I could restore this to its proper condition.
My question is, can it be used? The mortar between the clay tiles that line the flue is deteriorating, so the flue will need to be lined. Will this type of gas insert vent properly if a stainless steel liner is installed? Currently the flue is standard 8x13".
Of course, we can just put in a modern gas insert, but it would be very neat to keep the aesthetics of this antique beauty.
Any thoughts would be much appreciated!
Aaron
There is no guarantee that it WILL vent, especially if someone in your household turn on a bathroom vent,
an exterior vented range hood or a clothes dryer, while you have this unit burning.
The replacement air for any of those other items, may probably come down your
basement chimney, negating the draft needed for proper venting of combustion by-products.
Reactions: ThreshHawk
