Anybody burn Coal in a Heatmoor boiler?
john26
793
Wildwood MO
My brother and I are thinking of burning coal in his Heatmoor boiler mostly in colder weather due to have a limited amount of wood ready this year. We have read online about mixing wood and coal, but this doesn't seem right to me. We can get coal somewhat locally for around $80 a ton. We have burned lots of wood in this boiler a long with other forced air furnaces and stoves but never coal. I would appreciate any advice on the subject thanks.
Is your Heatmor designed to burn coal? Your manual will have this information.
It might work. If you have the auger clean-out clinkers might be a pain. Mixing wood and coal is easier than going all out coal. I'd try a few lumps and gradually mix in as you learn.
I wasn't out at the shop today to check model but I believe its a 400DCSS which is rated to burn coal or wood. I did check the online manual for that model it recommends using a shaker grate ( we don't have) and changing some air baffles.
I wouldn't want to burn coal without shaker grates. You may be better off mixing it.
