Ash dust mess with ShopVac
GrahamInVa
513
Eastern, Virginia
I'm too cheap to buy a ash vac so I have been using my shopvac to clean my stove. I took the regular filter out and bought some bags. They work OK, but I am still getting some ash dust in the house.
How does the HEPA filter work? Any other ideas?
Did you buy the bags because you were too cheap to buy the HEPA filter for the vac?? Seriously, all shop vacs i have seen have a HEPA filter available for just this purpose, vacuuming fine particles like dust, drywall sanding and other. Sure the filter might be $30-40 but who cares - it is the correct tool for the job.
Like something like this down to .3 microns
http://www.lowes.com/pd_328541-20097-9030711_4294857471_4294937087_?productId=3350222&Ns=p_product_prd_lis_ord_nbr|0||p_product_qty_sales_dollar|1&pl=1&currentURL;=/pl_Shop+Vacuum+Accessories_4294857471_4294937087_?page=2&Ns=p_product_prd_lis_ord_nbr|0||p_product_qty_sales_dollar|1&facetInfo;=
Graham,
Don't mess with cheap filters when playing with ash or any fine particulates, that stuff can kill you and it isn't a pleasant way to go. It ain't worth the risk.
Get a HEPA or drywall filter and use one of the fine cloth filters as well as they are pretty good and can be washed so the expensive one doesn't have to be replaced so often.
I use an extra long hose out the exhust port of the vac out the window near the stove for the dust that the filter does not capture. After every vac, I take the small vac outside, empty and shake the dust off the filter. This also prevents the risk of a shop vac fire and also allows the filter to be re-used and mostly dust free.
SmokeyTheBear said:
Graham,
A couple weeks ago I got a lung full when cleaning the pellet stove, it was awful.
I use the drywall dust bag (yellow), and the blue filter, which is the medium capacity. it sounds like you are only using the bag, definately use both. The bag is made to fit around the filter.
GrahamInVa said:
Thanks guys. I ordered the HEPA filter replacement. $28 off ebay. I didn't realize until now the HEPA is designed for small particles.
I use this with the drywall bags. No issues.
How often do you guys replace the filter and bag?
Yep. Drywall bags and HEPA here too.. On the Shop vac for the stove on the Shop vac for the Pellet Sifter.Works great. No dust. When running the the sifter, all I smell is pellets!!!! Mmmmmmm good!
I replace the filter when it starts to look "ratty." If any small holes or rips develop, etc. My ash vac manual says to replace the filter every 50 uses, but I have never gotten 50 uses out of mine. And with the bag I just rinse and dry it and have not yet had to replace that.
i attached a 10 foot garden hose to my shop vac....and just run it threw the window..works great for small places...
I bought a box store shop vac. The vac cost $30 and the HEPA filter for it also cost $30. It works great, blows no dust at all. Also, the filter is washable/reusable. I generally use it only for the yearly cleaning, unless there is a performance problem with the stove. I don't think it takes bags, or I would use them additionally.
Anyone tried cleaning the filter using an air compressor or leaf blower (blow inside out) to get more life out of the filter?
Just to be a little more sure when I'm cleaning out the stack, I got another hose for the shop vac, put it on the exhaust, and ran it out the window.
It's still nasty cleaning the filter though.
Longer hose is a good option, but get the longer hose for the suction side instead of the pressurized/blower side so that the vac sits outside. Otherwise ash will escape at the pressurized joint
Use my Rigid with the blue Heppa filter and the drywall bags. Stove must be absolutely cold. I do the cleaning inside the house and never have an issue with ash dust. I only clean out with the Rigid after a ton of pellets are burned. I see no problem to blowing out the blue Heppa with an air hose to get "a little extra mileage" out that filter.
When I feel the vac is losing suction, I switch filters (I have two) and take the dirty one to work and blow it out with compressed air. That really cleans it out well!
Use my Rigid with the blue Heppa filter and the drywall bags. Stove must be absolutely cold. I do the cleaning inside the house and never have an issue with ash dust. I only clean out with the Rigid after a ton of pellets are burned. I see no problem to blowing out the blue Heppa with an air hose to get “a little extra mileage†out that filter.
That's the one I have. I'll have to get some bags for mine. Although I get no dust with just the HEPA filter. To clean the filter, I take the it outside and wash it out with the garden hose. Keeps the dust down. Let it dry and it's like new. Hard to do in the real cold though.
stellep, where and which shop vac did you get for $30 ?
