    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. allegmtn New Member
    North Central PA
    I need to replace the auger motor on my stove. I've loosened the assembly feeder screw (allen bolt) so the nut spins freely but I still can't remove the motor shaft from the auger assembly. I've soaked it with penetrating oil and still no luck. Anyone ever had this happen before. Any ideas how to free this?
    #1
    Helpful Sponsor Ads!
  2. hearthtools Super Moderator
    Model and brand of Stove?
    Sometimes you have to work it out with a Pry bar.
    but you want to make sure you did loosen the correct set Screw/bolt.
    If seen some stoves (OLDER WINRICH) it had a set screw on the inside of the hopper at the auger.
  3. allegmtn New Member
    North Central PA
    Thanks, a pry bar was what it took. Sometimes you have to ignore dad's advice about "forcing things." Proves there is a place for brute force and a little leverage.
  4. MButkus Member
    Jersey
    The allen screws sometime push in to the metal rod, causing where the allen screw went to bulge out. Depending on the tight fit. You may need to pry them apart.
    Removing the allen screw can help too.
Thread Status:
