    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. rob bennett New Member
    Lynden, Washington
    I just rebuilt my chimney. I have a 50 gal natural gas water heater in the basement. It used to be vented just in the terra cotta flue. That wrecked the flues of course. Now the chimney is about 15 feet of cotta flue then an open chimney the last 9 feet.
    So I am looking at relining with the duravent aluminum liner kit.
    Will I be ok code wise to just run the liner without insulation? I can't find it specifically listed in any literature.
    Thanks!
    #1
    Helpful Sponsor Ads!
  2. theheatelement Feeling the Heat
    As long as it's ran in a masonry chimney you are fine... Some would say line it with insulation but with gas it's not as important as your not running very high temps and their is no creosote.
  3. jtp10181 Minister of Fire
    Madison, WI
    Yeap with gas you are fine just with the alum liner no insulation. As long as it is in masonry all the way through the roof.
Thread Status:
