    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. sclarke New Member
    Cincinnati, OH
    I have a regular Buck inserted into a masonry fireplace/chimney. I does not have a liner. I have sealed everything as best I can with hi heat silicone and insulation I bought from a wood stove salesman. When I get the stove real hot, it smells up the house. there is no smoke inside but there is some smell. could it be the bricks? I really cant describe the smell. silicone, gaskets, paint? does anyone else have issues with this?
    thanks
    #1
    Helpful Sponsor Ads!
  2. It sounds to me like you may have a cracked fire box. When the firebox is cracked, you will get smoke and other gases/fumes drawn into the inner chamber where the air blows through. Although the crack may not be large enough for you to see smoke in the house, odors will get blown into the room. I could be wrong. You may want to let the fire die out, remove all ash and brick from the firebox, and inspect it very well with good lighting. If the stove is cracked, you can have it re-welded. The most common area for cracks to form are on the rear wall and anywhere along the bottom edge. Also, check your door gaskets.
